Ga door naar hoofdinhoud
MacBook Air 13" Early 2015 SSD Upgrade to NVMe
Wat je nodig hebt
    • MacBook Air Late 2010 - Working - High Sierra, Catalina, M2 Samsung Evo 860, Adapter
    • MacBook Air 2011 - Unknown
    • MacBook Air 2012 - Unknown
    • MacBook Air 2013 - Unknown
    • MacBook Air 2014 - WD_black 500 + Sintech adapter, running MacOS Big Sur
    • MacBook Air Early 2015 - WORKING- Mojave 10.14.3 to Big Sur 11.0.1- Crucial P1 SSD NVME, Adapter.
    • MacBook Air 2017 - WORKING - High Sierra, Catalina and Big Sur - Samsung Evo 960, Adapter.
    • MacBook Air 2018 and forward - will not work, No removable drive
  1. MacBook Air 13" Early 2015 SSD Upgrade to NVMe, Lower Case: stap 2, afbeelding 1 van 1
    Gereedschap gebruikt in deze stap:
    P5 Pentalobe Screwdriver Retina MacBook Pro and Air
    $5.99
    Koop
    • Before proceeding, power down your MacBook. Close the display and lay it on a soft surface, top-side down.
    • Use a P5 Pentalobe driver to remove ten screws securing the lower case, of the following lengths:
    • Two 9 mm screws
    • Eight 2.6 mm screws
  2. MacBook Air 13" Early 2015 SSD Upgrade to NVMe: stap 3, afbeelding 1 van 1
    • Wedge your fingers between the display and the lower case and pull upward to pop the lower case off the Air.
  3. MacBook Air 13" Early 2015 SSD Upgrade to NVMe, Battery Connector: stap 4, afbeelding 1 van 2 MacBook Air 13" Early 2015 SSD Upgrade to NVMe, Battery Connector: stap 4, afbeelding 2 van 2
    • To ensure that everything is de-energized and won't turn on while you're working, it is recommended that you disconnect the battery.
    • Grab the clear plastic pull tab attached to the battery connector and pull it parallel to the board toward the front edge of the Air.
    • Do not lift upward on the connector as you disconnect it or you risk damage to the connector socket.
  4. MacBook Air 13" Early 2015 SSD Upgrade to NVMe, Solid-State Drive: stap 5, afbeelding 1 van 1
    • Remove the single 2.9 mm T5 Torx screw securing the SSD to the logic board.
  5. MacBook Air 13" Early 2015 SSD Upgrade to NVMe: stap 6, afbeelding 1 van 2 MacBook Air 13" Early 2015 SSD Upgrade to NVMe: stap 6, afbeelding 2 van 2
    • Gently lift the end of the SSD about half an inch and pull it straight out of its socket on the logic board.
    • Don't lift the SSD more than half an inch—doing so may damage the SSD or its socket on the logic board.
    • When reinstalling the SSD, be sure it is properly seated before reinstalling its retaining screw.
  6. MacBook Air 13" Early 2015 SSD Upgrade to NVMe, SSD - Alternate option using M.2 NVMe SSD: stap 7, afbeelding 1 van 2 MacBook Air 13" Early 2015 SSD Upgrade to NVMe, SSD - Alternate option using M.2 NVMe SSD: stap 7, afbeelding 2 van 2
    • Carefully insert the new SSD into the adapter, using the length of old drive as a reference for when the SSD is fully in the adapter. The lengths should be the same.
    • Insert the SSD and the adapter into the Socket, pushing inward in a straight fashion.
    • NVMe Drives can cause kernel panics due to sleep /hibernation issues. This can be turned off with the following command.
    • From a Terminal, use the following command to disable hibernation: ----"sudo pmset -a hibernatemode 0" ---- If you later want to enable hibernation, use: "sudo pmset -a hibernatemode 3"
Conclusie
18 andere personen hebben deze handleiding voltooid.
Dan
4.261 Reputatie
9 handleidingen geschreven
16 opmerkingen
Please advise ! I installed the Crucial P1 ssd with the adapter, i booted with the option/alt key and the ssd is not present, only the bootable usb ! On a MacBook Air early 2015
Dimitris Nikolopoulos - Antwoord
The disk will not be seen by the Disk Utility. But if you boot from a USB disk (option_r during boot) and start the Disk Utility program you’ll be able to see the new unformatted disk. Erase the drive. Then you can restore from a Time Machine backup or restart without the USB….This worked for me.
Olivier Fluri -
I also have the same problem, do i need latest operating system to detect these new drives?
Derrick Boateng -
Why does the guide recommend 5 hours?
After reading, I think this should take 30-45 minutes or possibly a bit less. Maybe I overlooked a step, or something in particular takes extra long? I’m interested to hear how this went for others who have tried.
excellent write up tho, I didn’t know there were NVME adapters available for these, awesome!
Daniel Cassel - Antwoord
The hardware only takes about a half hour, the installing the OS is what takes the time! To speed it up setup an external OS installer drive the faster the drive & interface the faster the install! A thunderbolt RAID’ed SSD is about as fast as you can get it takes just about an hour with it.
Dan -
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 16
Afgelopen 7 dagen: 149
Afgelopen 30 dagen: 556
Altijd: 48,631
