Ga door naar hoofdinhoud
Lenovo Thinkpad Keyboard Cleaning
Wat je nodig hebt
  1. Lenovo Thinkpad Keyboard Cleaning, Removing the Keyboard: stap 1, afbeelding 1 van 2 Lenovo Thinkpad Keyboard Cleaning, Removing the Keyboard: stap 1, afbeelding 2 van 2
    • Unfortunately, pictures of the removal were not taken but there are several YouTube videos demonstrating the process.
    • First, remove the battery and then remove two rubber bungs which are then visible in the battery compartment. Their surfaces are flush with the battery compartment roof.
    • Using two notches to gain access, slide the inter-key sheet upwards, revealing 6 small screws.
    • Remove these screws.
    • Now carefully lift the top of the keyboard and angle it towards you, revealing its two ribbon cables.
    • Gently lift the locking tabs on the ribbon cables and withdraw the ribbons. You can now remove the keyboard.
    • On different laptops, there are several methods of removing the keyboard. In some, you only need to release tabs along the top. Others are retained by screws under a bezel between the keyboard and the screen or they are accessed from the underside of the laptop.
  2. Lenovo Thinkpad Keyboard Cleaning, Removing A Key Cap: stap 2, afbeelding 1 van 2 Lenovo Thinkpad Keyboard Cleaning, Removing A Key Cap: stap 2, afbeelding 2 van 2
    • Insert an opening tool beneath one of the top corners of the key you wish to remove and angle it upwards until you feel it unclip.
    • Repeat at the other top corner.
    • You should now be able to lift the key cap off, moving it slightly in the direction of its lower edge.
    • On the underside of the key cap, notice the different sorts of clips at the top and bottom of the key. The top ones are designed to push on or pull off but the bottom ones push on only. For this reason, you must remove the key cap by first lifting the top corners (not the bottom) and re-engage the top clips first when you replace them.
  3. Lenovo Thinkpad Keyboard Cleaning, Removing the Butterfly Mechanism: stap 3, afbeelding 1 van 2 Lenovo Thinkpad Keyboard Cleaning, Removing the Butterfly Mechanism: stap 3, afbeelding 2 van 2
    • The butterfly mechanism has two pegs at the top and two at the bottom, which is retained under 4 metal clips.
    • Disengage one of the top pegs by gently pushing it up and out of its clip.
    • Repeat with the other top peg.
    • Take precautions as it may take flight as the second peg is released.
  4. Lenovo Thinkpad Keyboard Cleaning, Cleaning the Key Cap Well: stap 4, afbeelding 1 van 1
    • In the key cap well, you will see the silicone rubber snap-action key switch actuator. When depressed, this brings two contacts beneath it together. This is glued in place and you will probably tear it if you try to remove it.
    • First, blow out the dust and loose dirt. Then, clean out the well with isopropyl alcohol and an old toothbrush. Pay particular attention to the metallic area around the silicone. Allow it to dry.
  5. Lenovo Thinkpad Keyboard Cleaning, Replacing the Butterfly Mechanism and Key Cap: stap 5, afbeelding 1 van 1
    • To replace the butterfly mechanism, first, verify that you are holding it the right way round and the right way up.
    • Position the bottom pegs in their clips and then, holding it in position with a finger, press each of the top two pegs into their clips.
    • To replace the key cap, carefully place it accurately in position and first press the top corners in order to engage the top clips. Then press the bottom corners to engage the bottom clips.
    • Check that the key cap is level, all four clips engaged and that it moves freely up and down.
Conclusie
8 andere personen hebben deze handleiding voltooid.
Philip Le Riche
30.144 Reputatie
47 handleidingen geschreven
Restart Project Lid van Restart Project
Local Repair Groups
19 Leden
541 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 60
Afgelopen 7 dagen: 470
Afgelopen 30 dagen: 2,200
Altijd: 61,512
