Ga door naar hoofdinhoud
Kindle Paperwhite 2nd Generation Power Button Replacement
Wat je nodig hebt
  1. Kindle Paperwhite 2nd Generation Power Button Replacement, Power Button: stap 1, afbeelding 1 van 2 Kindle Paperwhite 2nd Generation Power Button Replacement, Power Button: stap 1, afbeelding 2 van 2
    • Insert plastic opening tool into the corners of the Paperwhite and slide around the edge perimeter to remove bezel.
    • Be sure to begin prying along the edges, these are the optimal points for removing the bezel.
  2. Kindle Paperwhite 2nd Generation Power Button Replacement: stap 2, afbeelding 1 van 2 Kindle Paperwhite 2nd Generation Power Button Replacement: stap 2, afbeelding 2 van 2
    • Remove the eleven 3.2 mm Phillips 000 screws from corners of mid-frame and from behind the black strip as shown.
    • Do not forget the screw in the middle of the black adhesive strip.
  3. Kindle Paperwhite 2nd Generation Power Button Replacement: stap 3, afbeelding 1 van 1
    • Carefully lift and remove the mid-frame.
  4. Kindle Paperwhite 2nd Generation Power Button Replacement: stap 4, afbeelding 1 van 2 Kindle Paperwhite 2nd Generation Power Button Replacement: stap 4, afbeelding 2 van 2
    • Remove the power button carefully using a blue plastic opening tool, and replace with a functional unit.
Conclusie
Tyler Davis
1.574 Reputatie
5 handleidingen geschreven
USF Tampa, Team 11-2, Blackwell Fall 2016 Lid van USF Tampa, Team 11-2, Blackwell Fall 2016
USFT-BLACKWELL-F16S11G2
4 Leden
7 handleidingen geschreven
5 opmerkingen
I have problems with my power button and this is very nice presentation, but I would like to know whether this button is an integral part of the back cover or can be purchased separately and, of course, where it can be purchased.
Thank you for answer and best regards,
Bojan
Bojan Briški - Antwoord
Seconding this: where exactly can I purchase the button?
Oren Leifer - Antwoord
Same for me…..where can I buy this button?
Rob Hoenstok - Antwoord
The power button must be part of an assembly that attaches to the main board in order for it to function. Where can I buy this assembly and not just the plastic button itself?
Roger Joseph
Roger joseph - Antwoord
This information is not useful unless the author tells us where to buy the power buttin.
Calvin Jordan - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 34
Altijd: 4,237
