Ga door naar hoofdinhoud
International Scout 80 Clutch replacement
Wat je nodig hebt
  1. International Scout 80 Clutch replacement, Clutch: stap 1, afbeelding 1 van 1
    • Start with removing passenger seat. Remove shifter boots and shift knobs. Next the center transmission/transfer case cover inside the vehicle.
  2. International Scout 80 Clutch replacement: stap 2, afbeelding 1 van 2 International Scout 80 Clutch replacement: stap 2, afbeelding 2 van 2
    • Next you'll need an impact gun or a large 1/2 inch drive breaker bar to remove the nut from inside the transfer case. It is behind the round cover on the transfer case. You should also remove the speedometer cable from the transfer case. This would be a good time to disconnect the drivelines, wrap tape around the U-joints to keep the caps from falling off and losing the needle bearings. I use pieces of coat hanger to hang the drive lines.
  3. International Scout 80 Clutch replacement: stap 3, afbeelding 1 van 1
    • To drain the fluid there are drain plugs on the transmission and transfer case, I still had quite a bit of oil in my transmission so you may get a mess when separating the units. There is a bolt that goes in from the front of the transmission into the transfer case, just to passenger side be sure to remove it.The two may be removed as a single unit but it's harder to maneuver it out of the hole and much heavier. ( or if you have the equipment you can drop it under after removing the shifters)
Conclusie
9 andere personen hebben deze handleiding voltooid.
junkemails70
279 Reputatie
1 Handleiding geschreven
2 opmerkingen
How do you adjust a hydroelectric clutch
josh helgeson - Antwoord
In most cases, the  clutch replacement  will involve replacing the clutch disc, releasing the pilot bearing, and replacing or resurfacing the flywheel.
5stars auto parts - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 20
Afgelopen 30 dagen: 123
Altijd: 8,090
