Ga door naar hoofdinhoud
Huntington GA41PS-RDS Acoustic Guitar String Replacement
Wat je nodig hebt
  1. Huntington GA41PS-RDS Acoustic Guitar String Replacement, Guitar String: stap 1, afbeelding 1 van 1
    • Place your guitar on a flat surface where you can easily identify the broken string.
  2. Huntington GA41PS-RDS Acoustic Guitar String Replacement: stap 2, afbeelding 1 van 3 Huntington GA41PS-RDS Acoustic Guitar String Replacement: stap 2, afbeelding 2 van 3 Huntington GA41PS-RDS Acoustic Guitar String Replacement: stap 2, afbeelding 3 van 3
    • Rotate the guitar pegs counter clockwise to loosen the broken string, until it can be removed by hand.
  3. Huntington GA41PS-RDS Acoustic Guitar String Replacement: stap 3, afbeelding 1 van 2 Huntington GA41PS-RDS Acoustic Guitar String Replacement: stap 3, afbeelding 2 van 2
    • Remove the bridge pin located at the lower end of the guitar.
    • Remove the other end of the broken string carefully. Keep the bridge pin removed.
  4. Huntington GA41PS-RDS Acoustic Guitar String Replacement: stap 4, afbeelding 1 van 3 Huntington GA41PS-RDS Acoustic Guitar String Replacement: stap 4, afbeelding 2 van 3 Huntington GA41PS-RDS Acoustic Guitar String Replacement: stap 4, afbeelding 3 van 3
    • Take the ball end of the new string and insert it into the bridge hole.
    • Insert the bridge pin back into the hole. Pull the rest of the string slightly to make sure it is tight.
    • Select the correct string to replace. I will be using the thinnest E string for this guide
  5. Huntington GA41PS-RDS Acoustic Guitar String Replacement: stap 5, afbeelding 1 van 3 Huntington GA41PS-RDS Acoustic Guitar String Replacement: stap 5, afbeelding 2 van 3 Huntington GA41PS-RDS Acoustic Guitar String Replacement: stap 5, afbeelding 3 van 3
    • Take the pointed end of the string and insert it into the string post.
    • Allow excess string to pass through. Tug on the string and make sure the string is parallel to the fret board.
    • Be careful. Do not hold too close to the sharp end of the string.
  6. Huntington GA41PS-RDS Acoustic Guitar String Replacement: stap 6, afbeelding 1 van 3 Huntington GA41PS-RDS Acoustic Guitar String Replacement: stap 6, afbeelding 2 van 3 Huntington GA41PS-RDS Acoustic Guitar String Replacement: stap 6, afbeelding 3 van 3
    • Make one loop around the string post with the excess string.
    • Rotate the tuning peg clockwise to tighten the string.
  7. Huntington GA41PS-RDS Acoustic Guitar String Replacement: stap 7, afbeelding 1 van 2 Huntington GA41PS-RDS Acoustic Guitar String Replacement: stap 7, afbeelding 2 van 2
    • Trim the excess string with the pliers. Make sure to cut close to the string post so it does not stick out.
Conclusie
Ruhail Khan
145 Reputatie
1 Handleiding geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 14
Altijd: 376
