Ga door naar hoofdinhoud
Huawei Ascend G510 disassembly
Wat je nodig hebt
  1. Huawei Ascend G510 disassembly, Huawei ascend g510: stap 1, afbeelding 1 van 1
    • My friend gave me it for 5€ (broken lcd and touch) so i took it apart
    • Yours may look different but tutorial like this should help you anyway :)
  2. Huawei Ascend G510 disassembly: stap 2, afbeelding 1 van 1
    • That's back of Huawei ascend g510
    • It's Inexpensive android phone
    • To open pry left down corner
    • You don't need any tools for this... You can pry any corner to pop the back open
  3. Huawei Ascend G510 disassembly: stap 3, afbeelding 1 van 1
    • First remove battery
  4. Huawei Ascend G510 disassembly, The battery: stap 4, afbeelding 1 van 2 Huawei Ascend G510 disassembly, The battery: stap 4, afbeelding 2 van 2
    • It's HB4W1H 3.7v 1750mAh (6.5Wh) Li-ion battery
    • Don't mess with Lithium ion batteries... (And don't take apart)
    • MADE IN CHINA... As everything
  5. Huawei Ascend G510 disassembly: stap 5, afbeelding 1 van 1
    • There are
    • 7 black T5 screws
    • 1 white T5 screw
    • 1 black Philipps #0 screw
    • Just remove all and sort them so you don't mix them
  6. Huawei Ascend G510 disassembly: stap 6, afbeelding 1 van 1
    • There are many clips along the sides
    • Don't pry to hard or you'll break some plastic
    • These clips really suck
  7. Huawei Ascend G510 disassembly: stap 7, afbeelding 1 van 1
    • First undo all connectors (lcd, touch, camera, sim/sd slot)
    • Main PCB is hold with clips and glue
    • Really frustrating to remove it... Glue or clips are everywhere
  8. Huawei Ascend G510 disassembly, The camera: stap 8, afbeelding 1 van 1
    • That's the camera
  9. Huawei Ascend G510 disassembly, The PCB: stap 9, afbeelding 1 van 2 Huawei Ascend G510 disassembly, The PCB: stap 9, afbeelding 2 van 2
    • Let's take look at pcb.
    • Unmodular and crusty... I don't like it at all
  10. Huawei Ascend G510 disassembly, The PCB (back): stap 10, afbeelding 1 van 2 Huawei Ascend G510 disassembly, The PCB (back): stap 10, afbeelding 2 van 2
    • As bad as front
  11. Huawei Ascend G510 disassembly: stap 11, afbeelding 1 van 2 Huawei Ascend G510 disassembly: stap 11, afbeelding 2 van 2
    • To separate glass (with touch) just heat it up to loosen adhesive
Conclusie
17 andere personen hebben deze handleiding voltooid.
Mateusz
1.498 Reputatie
2 handleidingen geschreven
3 opmerkingen
It just won't read my sim card,i was wondering if there is a setting that has been changed?
Michael Cummins - Antwoord
I have a good idea of what you are doing and how much you are doing. I have a nice day ahead of the individual named recipient
Dear sir
My phone huawei G510 runs but the display light is not coming please can u give me some suggestion how to repair it
sak - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 16
Altijd: 5,656
