Ga door naar hoofdinhoud
How to open a phone with a 3D printer (no joke)
Wat je nodig hebt
  1. How to open a phone with a 3D printer (no joke), How to open a phone with a 3D printer (no joke): stap 1, afbeelding 1 van 1
    • First, turn on your 3D printer and make sure that there is no residue (such as plastic) left on the print bed.
    • Make sure the printer is fully functional. It must not have any malfunctions, as higher temperatures are used here.
  2. How to open a phone with a 3D printer (no joke): stap 2, afbeelding 1 van 1
    • Now set the heat of the print bed to 70-80 °C, depending on how capable your printer is. You can safely leave the hotend cool, we don't need it.
    • Do not touch the print bed! You can get burned.
  3. How to open a phone with a 3D printer (no joke): stap 3, afbeelding 1 van 1
    • Put the cell phone on the print bed.
    • 30 seconds to one minute should be sufficient for most devices. However, if the adhesive is more stubborn, you can safely let it "cook" longer.
    • The print bed transfers a lot of direct heat quickly. That means you don't have to wait long.
    • If you're done with that, you can take the phone off the print bed again and start picking at it.
    • It is best to only handle the phone with protection, such as a kitchen towel or gloves! The underside of the cell phone gets very hot.
Conclusie
You are done, congratulations!
8 andere personen hebben deze handleiding voltooid.
Met dank aan deze vertalers:
de en
100%
Deze vertalers helpen ons de wereld te repareren! Wil je bijdragen?
Begin met vertalen ›
GamesNic
490 Reputatie
1 Handleiding geschreven
3 opmerkingen
wow, just wow
brilliant
Jeff H - Antwoord
i was thinking of the same idea, i think you can just use baking paper (Parchment paper) between phone and the build plate, just in case some plastic gets stuck to phone
Tommy - Antwoord
Dude. This rules. Why oh why did I never think of this 🙄. Heating up my pixel 3 with a hot air station like a fool, when. I have a perfectly good Bambu p1p.
Connor Shattuck - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 33
Afgelopen 30 dagen: 177
Altijd: 3,679
