Ga door naar hoofdinhoud
How to Restore a Damaged Cork Board
Wat je nodig hebt
  1. How to Restore a Damaged Cork Board, How to Restore a Damaged Cork Board: stap 1, afbeelding 1 van 1
    • Cover your work surface with a tarp.
  2. How to Restore a Damaged Cork Board: stap 2, afbeelding 1 van 1
    • Use a rag, soap, and water to scrub the damaged area to remove residual pieces of cork and glue.
    • Allow the area to dry.
  3. How to Restore a Damaged Cork Board: stap 3, afbeelding 1 van 1
    • Apply wood filler liberally on top of the holes.
  4. How to Restore a Damaged Cork Board: stap 4, afbeelding 1 van 2 How to Restore a Damaged Cork Board: stap 4, afbeelding 2 van 2
    • Smooth out the wood filler using a putty knife.
    • Hold the putty knife at an angle and use long strokes to flatten the filler as much as possible.
    • Wait 1 hour for the filler to dry.
  5. How to Restore a Damaged Cork Board: stap 5, afbeelding 1 van 1
    • Use 80-grit sandpaper to sand down the excess filler in a circular motion.
  6. How to Restore a Damaged Cork Board: stap 6, afbeelding 1 van 1
    • Cover the damaged area with a thin, even layer of wood sealant.
Conclusie
This guide will help you keep your old cork boards instead of trying to replace them. I hope you found our guide useful.
Annie Wilson
133 Reputatie
1 Handleiding geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 13
Afgelopen 30 dagen: 89
Altijd: 472
