Ga door naar hoofdinhoud
How to Replace a Valve Spring on a Trumpet
Wat je nodig hebt
  1. How to Replace a Valve Spring on a Trumpet, valve spring: stap 1, afbeelding 1 van 2 How to Replace a Valve Spring on a Trumpet, valve spring: stap 1, afbeelding 2 van 2
    • To pull out the valve, first twist the top of the valve open counterclockwise to detach it from the rest of the valve.
    • Pull the valve out of the trumpet.
  2. How to Replace a Valve Spring on a Trumpet: stap 2, afbeelding 1 van 2 How to Replace a Valve Spring on a Trumpet: stap 2, afbeelding 2 van 2
    • Near the top of the valve, twist the top part of the screw compartment off to access the screw.
    • Pull the old spring out and replace with the new one.
    • Reassemble the valve the same way it came apart.
  3. How to Replace a Valve Spring on a Trumpet: stap 3, afbeelding 1 van 2 How to Replace a Valve Spring on a Trumpet: stap 3, afbeelding 2 van 2
    • Before inserting the valve back into the trumpet, put enough valve oil on the valve so that that the surface is wet, but not dripping.
    • Insert the valve into the trumpet, and screw in the top clockwise.
    • Be sure to grasp the top of the valve and twist until a clicking sound is heard and the valve locks in place to ensure that the trumpet is ready for playing.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Isaac Trotta
125 Reputatie
1 Handleiding geschreven
Cal Poly, Team 23-4, Green Winter 2015 Lid van Cal Poly, Team 23-4, Green Winter 2015
CPSU-GREEN-W15S23G4
7 Leden
15 handleidingen geschreven
Één opmerking
I cannot manage to take out my valve it is so hard It’s a brand new trumpet sound like come out and then I don’t have valve oil
Flavio - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 43
Altijd: 8,222
