Ga door naar hoofdinhoud
How to Replace a Damaged Gutter Segment
Wat je nodig hebt
  1. How to Replace a Damaged Gutter Segment, Eavestrough Gutter Segment: stap 1, afbeelding 1 van 1
    • Identify the section of the gutter system that needs to be replaced, specifically the middle gutter.
  2. How to Replace a Damaged Gutter Segment: stap 2, afbeelding 1 van 2 How to Replace a Damaged Gutter Segment: stap 2, afbeelding 2 van 2
    • Using a screwdriver, remove the screws from the strip that holds the gutter to the wall.
    • Repeat this process for each strip along the length of the gutter.
    • Spread apart the strips to release the gutter.
    • When spreading apart the strips, they may have sharp edges. To ensure your safety, please use caution and wear protective gloves.
  3. How to Replace a Damaged Gutter Segment: stap 3, afbeelding 1 van 3 How to Replace a Damaged Gutter Segment: stap 3, afbeelding 2 van 3 How to Replace a Damaged Gutter Segment: stap 3, afbeelding 3 van 3
    • Locate the connecting points between the bottom gutter and the middle gutter.
    • Using a screwdriver, remove the screws.
    • Separate the bottom gutter from the middle gutter by sliding them apart.
  4. How to Replace a Damaged Gutter Segment: stap 4, afbeelding 1 van 3 How to Replace a Damaged Gutter Segment: stap 4, afbeelding 2 van 3 How to Replace a Damaged Gutter Segment: stap 4, afbeelding 3 van 3
    • Detach the top gutter from the connected fittings.
    • Position yourself securely on a ladder or elevated platform at the appropriate height to access the top gutter.
    • Place the removed top gutter and the middle gutter on the ground.
    • Inspect both the top gutter and the middle gutter for any damage. Assess whether they need to be entirely replaced or if repairs can be made.
    • If the damaged area is serious, you can only replace with a new segment (looking for environmentally friendly materials to protect the earth).
  5. How to Replace a Damaged Gutter Segment: stap 5, afbeelding 1 van 3 How to Replace a Damaged Gutter Segment: stap 5, afbeelding 2 van 3 How to Replace a Damaged Gutter Segment: stap 5, afbeelding 3 van 3
    • Slide the new middle gutter into the top gutter, inserting it gently until they are firmly connected.
    • Double-check that the alignment is correct and there are no gaps between the sections to avoid any drainage.
    • With the middle and top gutters connected, reattach the assembled gutters to the connected fittings.
  6. How to Replace a Damaged Gutter Segment: stap 6, afbeelding 1 van 3 How to Replace a Damaged Gutter Segment: stap 6, afbeelding 2 van 3 How to Replace a Damaged Gutter Segment: stap 6, afbeelding 3 van 3
    • Load a screw into the strip, positioning it so that it can be screwed into the holes of both the strip and the gutter.
    • Fold the strip around the gutter, aligning the holes of the strip with the corresponding holes on the gutter.
    • Screw the screws into the holes of the strip and the gutter, using a screwdriver.
    • Repeat this process for each strip along the length of the new middle gutter.
    • Take care not to overtighten the screw, as it may damage the gutter or strip the threads.
  7. How to Replace a Damaged Gutter Segment: stap 7, afbeelding 1 van 3 How to Replace a Damaged Gutter Segment: stap 7, afbeelding 2 van 3 How to Replace a Damaged Gutter Segment: stap 7, afbeelding 3 van 3
    • Position the bottom gutter in its intended location, ensuring that the holes on both pieces line up properly.
    • Using a screwdriver, tighten the screws to fasten the middle and bottom gutters together.
    • Replacement Complete!
Eindstreep
Gavin Luc
145 Reputatie
1 Handleiding geschreven
York University, Team D-74, O'Regan Fall 2023 Lid van York University, Team D-74, O'Regan Fall 2023
YORK-O'REGAN-F23SDG74
1 Lid
2 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 5
Afgelopen 7 dagen: 20
Afgelopen 30 dagen: 79
Altijd: 593
