Ga door naar hoofdinhoud
How to Replace Big Berkey Water Filters
Wat je nodig hebt
  1. How to Replace Big Berkey Water Filters, Filters: stap 1, afbeelding 1 van 2 How to Replace Big Berkey Water Filters, Filters: stap 1, afbeelding 2 van 2
    • Take the top half of your Berkey off, and place it to the side of your work station.
  2. How to Replace Big Berkey Water Filters: stap 2, afbeelding 1 van 2 How to Replace Big Berkey Water Filters: stap 2, afbeelding 2 van 2
    • Unscrew the White Elements by twisting counterclockwise.
  3. How to Replace Big Berkey Water Filters: stap 3, afbeelding 1 van 3 How to Replace Big Berkey Water Filters: stap 3, afbeelding 2 van 3 How to Replace Big Berkey Water Filters: stap 3, afbeelding 3 van 3
    • Unscrew the Black Element filters by twisting the black washers counterclockwise.
    • Remove the filters from the top compartment.
  4. How to Replace Big Berkey Water Filters: stap 4, afbeelding 1 van 2 How to Replace Big Berkey Water Filters: stap 4, afbeelding 2 van 2
    • Clean both the top and bottom tank compartments with a sponge.
    • Make sure to scrub both compartments clean of any mineral build-up that may have accumulated.
  5. How to Replace Big Berkey Water Filters: stap 5, afbeelding 1 van 3 How to Replace Big Berkey Water Filters: stap 5, afbeelding 2 van 3 How to Replace Big Berkey Water Filters: stap 5, afbeelding 3 van 3
    • Securely attach the priming tool to the Black Elements nozzle.
    • Push the filter nozzle against the tap for 10 seconds per filter to remove any impurities.
    • Run your sink water at a medium to slow flow-rate, to avoid water spraying everywhere.
  6. How to Replace Big Berkey Water Filters: stap 6, afbeelding 1 van 2 How to Replace Big Berkey Water Filters: stap 6, afbeelding 2 van 2
    • Leave equipment to air dry.
  7. How to Replace Big Berkey Water Filters: stap 7, afbeelding 1 van 3 How to Replace Big Berkey Water Filters: stap 7, afbeelding 2 van 3 How to Replace Big Berkey Water Filters: stap 7, afbeelding 3 van 3
    • Place your new Black Element filters through the holes in the top compartment.
    • Continue to screw the washer around the nozzle to secure the Black Element in place.
  8. How to Replace Big Berkey Water Filters: stap 8, afbeelding 1 van 3 How to Replace Big Berkey Water Filters: stap 8, afbeelding 2 van 3 How to Replace Big Berkey Water Filters: stap 8, afbeelding 3 van 3
    • Screw our new White Element filters over the nozzle of the Black Element filters, and repeat to attach all pieces securely.
  9. How to Replace Big Berkey Water Filters: stap 9, afbeelding 1 van 1
    • Enjoy your clean and purified drinking water from your Big Berkey for years to come.
Conclusie
Shannon Cash
169 Reputatie
1 Handleiding geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 5
Afgelopen 7 dagen: 21
Afgelopen 30 dagen: 61
Altijd: 542
