Inleiding
If your beloved furry friend (either dog or cat) decided they wanted to chew through your wooden furniture, use this guide to repair and refinish your furniture rather than throwing it away.
Before using this guide, inspect the amount of damage to the piece of wooden furniture and assess how much wood filler, stain, and polyurethane you will need to purchase to complete the project.
You might want to think about bringing a wood piece with you to match the stain or have a picture on hand to match the color. Also, using gloves to stain the wood avoids your hands from becoming messy during the staining process.
There is an option to purchase the stain and polyurethane all in one, but be aware that this step speeds up the process, and you cannot remove the stain. Purchasing the stain separately allows you to add the required coats to match the furniture thoroughly.
Before beginning, make sure you have a tarp or old sheet underneath the wooden furniture to collect debris from sanding, wood filler, and stain.
Wat je nodig hebt
Inspect the damage from the chew marks.
Look for finer areas with smaller chewed up marks.
Don’t forget to reassemble your wooden furniture. In this guide, the mirror has two screws that secure the mirror to its stand.
Één andere persoon heeft deze handleiding voltooid.
