Ga door naar hoofdinhoud
How to Repair a Stuck Car Door Latch
Wat je nodig hebt
  1. How to Repair a Stuck Car Door Latch, How to Repair a Stuck Car Door Latch: stap 1, afbeelding 1 van 2 How to Repair a Stuck Car Door Latch, How to Repair a Stuck Car Door Latch: stap 1, afbeelding 2 van 2
    • On the car door that will not close, examine the door latch located near the handle on the side of the door.
    • The car door latch will be locked in a closed position.
  2. How to Repair a Stuck Car Door Latch: stap 2, afbeelding 1 van 3 How to Repair a Stuck Car Door Latch: stap 2, afbeelding 2 van 3 How to Repair a Stuck Car Door Latch: stap 2, afbeelding 3 van 3
    • Position a screwdriver between the legs of the locked door latch.
    • You may use any size screwdriver that will fit between the latch.
  3. How to Repair a Stuck Car Door Latch: stap 3, afbeelding 1 van 1
    • Pull the exterior car door handle.
  4. How to Repair a Stuck Car Door Latch: stap 4, afbeelding 1 van 2 How to Repair a Stuck Car Door Latch: stap 4, afbeelding 2 van 2
    • While the exterior door handle is being pulled, push the screwdriver against the left leg of the latch.
  5. How to Repair a Stuck Car Door Latch: stap 5, afbeelding 1 van 3 How to Repair a Stuck Car Door Latch: stap 5, afbeelding 2 van 3 How to Repair a Stuck Car Door Latch: stap 5, afbeelding 3 van 3
    • Use the screwdriver to push the latch upwards into the final unlocked position.
  6. How to Repair a Stuck Car Door Latch: stap 6, afbeelding 1 van 2 How to Repair a Stuck Car Door Latch: stap 6, afbeelding 2 van 2
    • Close the car door to ensure the latch has been properly reset.
Eindstreep
11 andere personen hebben deze handleiding voltooid.
Kennedy Coleman
439 Reputatie
1 Handleiding geschreven
UW Tacoma, Team S1-G30, Cardinal Spring 2020 Lid van UW Tacoma, Team S1-G30, Cardinal Spring 2020
UWT-CARDINAL-S20S1G30
1 Lid
5 handleidingen geschreven
14 opmerkingen
Thanks a lot, you have saved me from one !&&* of a problem!
dee Knight - Antwoord
This helped me so much!! Thank you!!!
Jasmine Roman - Antwoord
Perfect. So simple. Excellent advice once again from iFixit. Thank you.
Bill Smith - Antwoord
Thank you so much! I figured it out because of this post!
Sharan Sahota - Antwoord
I love this solution. It literally just saved me. Thank you soo much.
Edith Turkson - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 181
Afgelopen 7 dagen: 1,197
Afgelopen 30 dagen: 5,234
Altijd: 112,354
