Ga door naar hoofdinhoud
How to Repair a Small Hole in a Spanish Knife Textured Wall
Wat je nodig hebt
  1. How to Repair a Small Hole in a Spanish Knife Textured Wall, How to Repair a Small Hole in a Spanish Knife Textured Wall: stap 1, afbeelding 1 van 2 How to Repair a Small Hole in a Spanish Knife Textured Wall, How to Repair a Small Hole in a Spanish Knife Textured Wall: stap 1, afbeelding 2 van 2
    • Remove any debris from the hole in the wall.
  2. How to Repair a Small Hole in a Spanish Knife Textured Wall: stap 2, afbeelding 1 van 1
    • Scoop some DryDex Spackling on to your plastic taping knife.
  3. How to Repair a Small Hole in a Spanish Knife Textured Wall: stap 3, afbeelding 1 van 2 How to Repair a Small Hole in a Spanish Knife Textured Wall: stap 3, afbeelding 2 van 2
    • Fill the hole with spackle.
  4. How to Repair a Small Hole in a Spanish Knife Textured Wall: stap 4, afbeelding 1 van 2 How to Repair a Small Hole in a Spanish Knife Textured Wall: stap 4, afbeelding 2 van 2
    • Gently move the taping knife over the newly covered hole in multiple directions.
    • This will ensure the spackle completely fills the hole.
    • Let the DryDex Spackle dry.
    • You will know the spackle is dry when it turns from pink to white.
  5. How to Repair a Small Hole in a Spanish Knife Textured Wall: stap 5, afbeelding 1 van 1
    • Sand the newly spackled area down until the spackle is level with the original wall.
  6. How to Repair a Small Hole in a Spanish Knife Textured Wall: stap 6, afbeelding 1 van 2 How to Repair a Small Hole in a Spanish Knife Textured Wall: stap 6, afbeelding 2 van 2
    • Scoop some All Purpose Joint Compound on to your putty knife.
  7. How to Repair a Small Hole in a Spanish Knife Textured Wall: stap 7, afbeelding 1 van 2 How to Repair a Small Hole in a Spanish Knife Textured Wall: stap 7, afbeelding 2 van 2
    • Smooth the joint compound on the wall, covering the area you want to re-texture.
  8. How to Repair a Small Hole in a Spanish Knife Textured Wall: stap 8, afbeelding 1 van 2 How to Repair a Small Hole in a Spanish Knife Textured Wall: stap 8, afbeelding 2 van 2
    • Gently drag the putty knife through the joint compound to create ridges.
    • Creating ridges is a creative and unique process. You get to decide how close you want the ridges together and at what angle to make the ridges.
    • Let the joint compound completely dry.
    • You will know the Joint Compound is dry when it turns from grey to white.
  9. How to Repair a Small Hole in a Spanish Knife Textured Wall: stap 9, afbeelding 1 van 2 How to Repair a Small Hole in a Spanish Knife Textured Wall: stap 9, afbeelding 2 van 2
    • Mix the paint that you have leftover from the first time you painted the wall.
  10. How to Repair a Small Hole in a Spanish Knife Textured Wall: stap 10, afbeelding 1 van 2 How to Repair a Small Hole in a Spanish Knife Textured Wall: stap 10, afbeelding 2 van 2
    • Paint the section of the wall that you re-textured.
    • Paint each ridge.
    • Let the paint completely dry.
Conclusie
You’ve successfully spackled, textured, and painted. Your wall is now as good as new!
Kayla Elder
198 Reputatie
1 Handleiding geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 37
Altijd: 899
