Ga door naar hoofdinhoud
How to Remove Wax From Clothing
Wat je nodig hebt
  1. How to Remove Wax From Clothing, Removing Dried Wax: stap 1, afbeelding 1 van 1
    • Set up the ironing board.
    • Plug in the iron and turn it on.
    • Your iron may need some time to heat up, especially if it is an older model.
  2. How to Remove Wax From Clothing: stap 2, afbeelding 1 van 1
    • Place your piece of clothing onto the ironing board.
  3. How to Remove Wax From Clothing: stap 3, afbeelding 1 van 2 How to Remove Wax From Clothing: stap 3, afbeelding 2 van 2
    • Take your brown paper bag and fold it over the affected area, being sure to cover both sides of the waxy clothing.
  4. How to Remove Wax From Clothing: stap 4, afbeelding 1 van 1
    • Press the iron on top of the brown paper bag.
    • Move the iron around as if you are ironing wrinkles out.
    • Be careful not to burn your fingers.
  5. How to Remove Wax From Clothing: stap 5, afbeelding 1 van 2 How to Remove Wax From Clothing: stap 5, afbeelding 2 van 2
    • Lift up the brown paper bag once it looks like the oil has saturated the bag.
    • Repeat steps 3-5 with new bags, until the remainder of the wax is soaked up.
  6. How to Remove Wax From Clothing: stap 6, afbeelding 1 van 1
    • Feel free to wash your item now that the wax is removed, just as you normally would.
Conclusie
To finish getting wax out it is not a bad idea to wash your item, if possible, in a washing machine for a clothing item or use carpet wash for the carpet.
Molly Green
133 Reputatie
1 Handleiding geschreven
UW Tacoma, Team S1-G7, Cardinal Spring 2020 Lid van UW Tacoma, Team S1-G7, Cardinal Spring 2020
UWT-CARDINAL-S20S1G7
1 Lid
2 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 11
Afgelopen 30 dagen: 46
Altijd: 562
