Ga door naar hoofdinhoud
How to Refurbish a Cat Scratching Post
Wat je nodig hebt
  1. How to Refurbish a Cat Scratching Post, How to Refurbish a Cat Scratching Post: stap 1, afbeelding 1 van 2 How to Refurbish a Cat Scratching Post, How to Refurbish a Cat Scratching Post: stap 1, afbeelding 2 van 2
    • A worn down cat scratching post is neither fun to look at, nor do cats like it. But this a quick and easy fix that uses minimal materials and tools!
    • Opal is not amused.
  2. How to Refurbish a Cat Scratching Post: stap 2, afbeelding 1 van 3 How to Refurbish a Cat Scratching Post: stap 2, afbeelding 2 van 3 How to Refurbish a Cat Scratching Post: stap 2, afbeelding 3 van 3
    • Begin by cutting a section of the existing rope at the top with a utility knife.
    • Grab onto the cut piece of rope and begin unraveling it. Some sections may be glued down, so don't be shy and give it a good pull to remove the rope.
    • Sisal rope has a very rough feel to it, so using gloves will prevent the rope from scratching up your hands.
  3. How to Refurbish a Cat Scratching Post: stap 3, afbeelding 1 van 3 How to Refurbish a Cat Scratching Post: stap 3, afbeelding 2 van 3 How to Refurbish a Cat Scratching Post: stap 3, afbeelding 3 van 3
    • To save time and rope, you can stop about half-way down, since the bottom portion is likely still in good shape.
    • When you reach a stopping point, cut the rope with your utility knife and glue the end back onto the post with hot glue.
  4. How to Refurbish a Cat Scratching Post: stap 4, afbeelding 1 van 2 How to Refurbish a Cat Scratching Post: stap 4, afbeelding 2 van 2
    • Take the new sisal rope and glue the end to the post right where the old rope left off.
  5. How to Refurbish a Cat Scratching Post: stap 5, afbeelding 1 van 2 How to Refurbish a Cat Scratching Post: stap 5, afbeelding 2 van 2
    • Begin wrapping the new rope around the post.
    • It's important to keep the rope tight as you wrap it so it doesn't come loose when your cat scratches on it.
  6. How to Refurbish a Cat Scratching Post: stap 6, afbeelding 1 van 1
    • Every few layers or so, put a dab of hot glue on the post and continue wrapping the rope around the post.
  7. How to Refurbish a Cat Scratching Post: stap 7, afbeelding 1 van 2 How to Refurbish a Cat Scratching Post: stap 7, afbeelding 2 van 2
    • When you get to the top, cut the excess rope off and put one last dab of glue on the post to hold the end of the rope in place.
  8. How to Refurbish a Cat Scratching Post: stap 8, afbeelding 1 van 1
    • Good as new!
Eindstreep
49 andere personen hebben deze handleiding voltooid.
Craig Lloyd
35.807 Reputatie
82 handleidingen geschreven
6 opmerkingen
I love this idea, but I’m wary of using hot glue to fix the rope to the base - unless the heat from the glue changes the structure of the material (like with foam for example), the hold isn’t very strong in my experience. Have you experimented with other adhesives?
Erin Lightman Renner - Antwoord
Our hot glue gun from Michaels affixed the sisal rope well when I used thick suede gloves (like gardening or hawk gloves) to hold the glued rope while winding it around the pole. You may need to purchase a hotter temperature glue gun. We had to because our first one didn't work well.
noone - Antwoord
I just bought some sisal rope to do a repair and I agree that hot glue for me is not the ticket. I would prefer to actually tie the rope onto and then off of the stand. Hot glue alone would not be enough I doubt. Just a dab to hold in place while wrapping.
Susan Motley - Antwoord
What other adhesives that might work?
Kristine Gray - Antwoord
Hot glue works just fine if you wrap the rope tightly enough. I have repaired several this way and they have lasted for a couple of years.
Cat Calhoun - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 29
Afgelopen 7 dagen: 176
Afgelopen 30 dagen: 916
Altijd: 68,144
