Ga door naar hoofdinhoud
How to Reattach the Head of a Mailbox to the Base
Wat je nodig hebt
  1. How to Reattach the Head of a Mailbox to the Base, How to Reattach the Head of a Mailbox to the Base: stap 1, afbeelding 1 van 2 How to Reattach the Head of a Mailbox to the Base, How to Reattach the Head of a Mailbox to the Base: stap 1, afbeelding 2 van 2
    • Inspect the head of the mailbox to see where the detachment is located.
  2. How to Reattach the Head of a Mailbox to the Base: stap 2, afbeelding 1 van 2 How to Reattach the Head of a Mailbox to the Base: stap 2, afbeelding 2 van 2
    • Gather all materials needed.
    • Adhesive can be included depending on the tight fit you desire.
  3. How to Reattach the Head of a Mailbox to the Base: stap 3, afbeelding 1 van 3 How to Reattach the Head of a Mailbox to the Base: stap 3, afbeelding 2 van 3 How to Reattach the Head of a Mailbox to the Base: stap 3, afbeelding 3 van 3
    • Measure out the wood plank to match the length and width of the mailbox head.
  4. How to Reattach the Head of a Mailbox to the Base: stap 4, afbeelding 1 van 3 How to Reattach the Head of a Mailbox to the Base: stap 4, afbeelding 2 van 3 How to Reattach the Head of a Mailbox to the Base: stap 4, afbeelding 3 van 3
    • Use a hammer or mallet to nail this wood plank to the bottom of mailbox head. Use at least four nails for this task.
    • Use gloves, if deemed necessary!
  5. How to Reattach the Head of a Mailbox to the Base: stap 5, afbeelding 1 van 2 How to Reattach the Head of a Mailbox to the Base: stap 5, afbeelding 2 van 2
    • Screw the sides down for a stronger fit using at least four screws.
  6. How to Reattach the Head of a Mailbox to the Base: stap 6, afbeelding 1 van 1
    • Align the mailbox head back on the post.
  7. How to Reattach the Head of a Mailbox to the Base: stap 7, afbeelding 1 van 2 How to Reattach the Head of a Mailbox to the Base: stap 7, afbeelding 2 van 2
    • Hammer down the head to the post of the mailbox with at least three more nails.
    • Add adhesive if necessary for a sturdier attachment.
    • Since your hands are inside the mailbox, it may be best to use gloves for this task.
Eindstreep
Terrell Cobbins
145 Reputatie
1 Handleiding geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 6
Afgelopen 7 dagen: 15
Afgelopen 30 dagen: 32
Altijd: 302
