Ga door naar hoofdinhoud
How to Reattach a Broken Table Leg
Wat je nodig hebt
  1. How to Reattach a Broken Table Leg, How to Reattach a Broken Table Leg: stap 1, afbeelding 1 van 1
    • Carefully place the table on an even surface and identify the broken parts.
  2. How to Reattach a Broken Table Leg: stap 2, afbeelding 1 van 1
    • Carefully place the table with the tabletop face down on a clean cloth or plastic cover to prevent scratching.
    • You might need some assistance depending on the size of the table.
  3. How to Reattach a Broken Table Leg: stap 3, afbeelding 1 van 2 How to Reattach a Broken Table Leg: stap 3, afbeelding 2 van 2
    • Remove the screws from the broken leg.
    • I am using a Mastercraft flathead 3 mm screwdriver in this step. Your screwdriver type will depend on the screw. Follow this guide to learn more about screwdriver types.
    • Remove the broken leg.
    • Use a paper towel to clean the surface of the table and legs.
  4. How to Reattach a Broken Table Leg: stap 4, afbeelding 1 van 2 How to Reattach a Broken Table Leg: stap 4, afbeelding 2 van 2
    • Caution: If you have sensitive skin, avoid direct contact with the glue and use gloves before performing this step.
    • Caution: Use adequate ventilation or wear a mask to prevent inhaling the glue fumes.
    • Carefully apply the glue on the part that connects the table and legs.
  5. How to Reattach a Broken Table Leg: stap 5, afbeelding 1 van 1
    • Press the leg against the glue for few minutes.
    • Allow the glue to dry for at least 10 minutes.
  6. How to Reattach a Broken Table Leg: stap 6, afbeelding 1 van 1
    • Once the glue is dry, insert the screws.
  7. How to Reattach a Broken Table Leg: stap 7, afbeelding 1 van 3 How to Reattach a Broken Table Leg: stap 7, afbeelding 2 van 3 How to Reattach a Broken Table Leg: stap 7, afbeelding 3 van 3
    • Use an electric drill or a screwdriver to tighten the screws.
  8. How to Reattach a Broken Table Leg: stap 8, afbeelding 1 van 1
    • Use a paper towel to remove extra glue stains.
    • Allow the table to dry for 24 hours before turning the table.
  9. How to Reattach a Broken Table Leg: stap 9, afbeelding 1 van 2 How to Reattach a Broken Table Leg: stap 9, afbeelding 2 van 2
    • After 24 hours, carefully return the table to the original position.
    • Depending on the size of the table, you might need some assistance to turn the table.
Conclusie
Repeat these steps to fix any other broken legs on the table.
Één andere persoon heeft deze handleiding voltooid.
Kunpriya Aggarwal
246 Reputatie
1 Handleiding geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 6
Afgelopen 7 dagen: 55
Afgelopen 30 dagen: 204
Altijd: 9,727
