Ga door naar hoofdinhoud
How to Put an iPhone Into Recovery Mode
Video overzicht
  1. How to Put an iPhone Into Recovery Mode, Connect to a Computer: stap 1, afbeelding 1 van 1
    • Using a USB cable, connect your iPhone to a Mac or PC with the most current version of iTunes installed.
  2. How to Put an iPhone Into Recovery Mode, Button Combination Press: stap 2, afbeelding 1 van 1
    • If you have an iPhone 8 or later: press and release the Volume Up button, press and release the Volume Down button, press and hold the Side button until you see the Recovery Mode screen
    • For an iPhone 7 or 7 Plus: Press and hold the Side button and Volume Down button until you see the Recovery Mode screen.
    • On iPhone 6s or earlier: Press and hold both the Power button and the Home button until you see the Recovery Mode screen.
  3. How to Put an iPhone Into Recovery Mode, Recover the device: stap 3, afbeelding 1 van 2 How to Put an iPhone Into Recovery Mode, Recover the device: stap 3, afbeelding 2 van 2
    • For macOS Catalina and Later: Open Finder. In the sidebar, you will see your device. When you click on it, a pop up will appear prompting for Update or Restore. Update will reinstall the OS without erasing data. If the update option fails or you are locked out of your device, restore will reinstall the OS and erase all data.
    • For macOS Mojave and Prior or Windows: Open iTunes. In the top left corner will be an icon for the iPhone. When you click it, a popup will appear prompting to Update or Restore. Update to reinstall the OS without erasing data. If the update option fails or you are locked out of your device, restore will reinstall the OS and erase all data.
Conclusie
To put your iOS device in recovery mode, follow these instructions.
33 andere personen hebben deze handleiding voltooid.
Duckida
1.200 Reputatie
1 Handleiding geschreven
7 opmerkingen
My power button is not working on an iphone 6, so I can't use these directions! Do you have a work around for this situation?
Thanks
Jeff
Jeff Lawton - Antwoord
On iPhone 6, the power button is really only necessary to turn the device off. You can also accomplish this by disconnecting the battery. Which isn't ideal, but it's better than not being able to do it at all. After it's off, reconnect the battery, then hold down the home button and connect the lightning cable from the USB cable to your computer.
Alisha C -
Some repair tools can get the device into or out of Recovery Mode without pressing buttons physically. TunesKit iOS System Recovery has this feature for totally free, you can use this to put your iPhone into Recovery Mode without any limits.
pony King -
My home button is not functioning, so even if I disconnect the battery and reconnect it, I will be at the same place. I had to use the digital home button to use the phone before it got disabled. It's that white circular digital button that can be used as an alternative when the physical home key is not functioning.
My phone just suddenly off by itself an iPhone 12 Pro Max please I don’t know what to do
Amadi Divine - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 175
Afgelopen 7 dagen: 1,151
Afgelopen 30 dagen: 4,706
Altijd: 67,438
