Ga door naar hoofdinhoud
How to Install an HID Conversion Kit
Wat je nodig hebt
  1. How to Install an HID Conversion Kit, Headlights: stap 1, afbeelding 1 van 2 How to Install an HID Conversion Kit, Headlights: stap 1, afbeelding 2 van 2
    • Open the hood.
    • Locate the back of the headlights and remove the bolts holding the headlight housing.
  2. How to Install an HID Conversion Kit: stap 2, afbeelding 1 van 1
    • Unplug the stock harness and remove the headlights.
  3. How to Install an HID Conversion Kit: stap 3, afbeelding 1 van 2 How to Install an HID Conversion Kit: stap 3, afbeelding 2 van 2
    • Remove battery negative terminal.
    • Remove headlight cover and remove factory halogen bulb.
  4. How to Install an HID Conversion Kit: stap 4, afbeelding 1 van 1
    • Take out the HID bulb from the plastic shell and remove the circular plastic piece.
    • Remember not to touch the HID bulb glass!
    • If you accidentally touch it, you can clean it with some rubbing alcohol.
  5. How to Install an HID Conversion Kit: stap 5, afbeelding 1 van 2 How to Install an HID Conversion Kit: stap 5, afbeelding 2 van 2
    • Screw in the HID bulb back into the headlight housing.
    • Connect the wires of the HID bulb to the ballast and then connect the HID ballast back to the stock harness.
  6. How to Install an HID Conversion Kit: stap 6, afbeelding 1 van 1
    • Before you mount the ballast, test the HID light to make sure it lights up.
    • If not, turn the adapter wire 180 degrees.
    • Mount the HID ballast with zip ties.
  7. How to Install an HID Conversion Kit: stap 7, afbeelding 1 van 3 How to Install an HID Conversion Kit: stap 7, afbeelding 2 van 3 How to Install an HID Conversion Kit: stap 7, afbeelding 3 van 3
    • Put everything (like the headlight housing) back.
    • Enjoy!
Conclusie
Enjoy your new HID Conversion Kit and upgraded headlights or fog lights.
6 andere personen hebben deze handleiding voltooid.
Eric Wu
3.357 Reputatie
23 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 21
Afgelopen 30 dagen: 92
Altijd: 16,320
