Ga door naar hoofdinhoud
How to Get Dents Out of Wood
Wat je nodig hebt
  1. How to Get Dents Out of Wood, How to Get Dents Out of Wood: stap 1, afbeelding 1 van 3 How to Get Dents Out of Wood, How to Get Dents Out of Wood: stap 1, afbeelding 2 van 3 How to Get Dents Out of Wood, How to Get Dents Out of Wood: stap 1, afbeelding 3 van 3
    • Fill a medium-sized bowl with room-temperature water.
    • Dip a hand towel into the bowl of water.
    • Wring the hand towel out a bit until it is damp rather than dripping wet.
  2. How to Get Dents Out of Wood: stap 2, afbeelding 1 van 2 How to Get Dents Out of Wood: stap 2, afbeelding 2 van 2
    • In the wood surface, find the dent you wish to remove.
    • Place the damp hand towel over the dented area as flat as possible.
  3. How to Get Dents Out of Wood: stap 3, afbeelding 1 van 2 How to Get Dents Out of Wood: stap 3, afbeelding 2 van 2
    • Set your flat iron to its highest setting.
    • Do NOT touch the metal part of the flat iron while it is on.
  4. How to Get Dents Out of Wood: stap 4, afbeelding 1 van 3 How to Get Dents Out of Wood: stap 4, afbeelding 2 van 3 How to Get Dents Out of Wood: stap 4, afbeelding 3 van 3
    • Firmly press the flat iron down on the damp hand towel.
    • While pressing down, move the iron in circular or back and forth motions.
  5. How to Get Dents Out of Wood: stap 5, afbeelding 1 van 1
    • Continue the circular or back and forth motions until the hand towel is dry.
  6. How to Get Dents Out of Wood: stap 6, afbeelding 1 van 1
    • Repeat steps 1-5 until the dent is gone.
    • Turn off the flat iron after finishing.
    • Be sure to allow time for the iron to cool down after turning it off. Do NOT touch the metal or place it face down during this time.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Matthew Clarke
160 Reputatie
1 Handleiding geschreven
UC Davis, Team 1-12, Morris Winter 2023 Lid van UC Davis, Team 1-12, Morris Winter 2023
UCD-MORRIS-W23S1G12
3 Leden
2 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 11
Afgelopen 30 dagen: 53
Altijd: 375
