Ga door naar hoofdinhoud
How to Fix a Papasan Chair Base
Wat je nodig hebt
  1. How to Fix a Papasan Chair Base, How to Fix a Papasan Chair Base: stap 1, afbeelding 1 van 2 How to Fix a Papasan Chair Base, How to Fix a Papasan Chair Base: stap 1, afbeelding 2 van 2
    • Remove and save rattan from broken sections.
  2. How to Fix a Papasan Chair Base: stap 2, afbeelding 1 van 1
    • Remove old nails from the sections that have separated. Pliers may be helpful for nails that are hard to reach with the claw of a hammer.
  3. How to Fix a Papasan Chair Base: stap 3, afbeelding 1 van 2 How to Fix a Papasan Chair Base: stap 3, afbeelding 2 van 2
    • Glue the split wood pieces together, clamp, and let them dry.
  4. How to Fix a Papasan Chair Base: stap 4, afbeelding 1 van 1
    • Nail the thin decorative wood pieces to the larger sections of the frame.
  5. How to Fix a Papasan Chair Base: stap 5, afbeelding 1 van 1
    • Screw the circular base and upper to the vertical supports that have become disconnected.
  6. How to Fix a Papasan Chair Base: stap 6, afbeelding 1 van 1
    • Screw together two ends of the circular part of the frame. Align the screw to be perpendicular to the seam where the two ends connect.
  7. How to Fix a Papasan Chair Base: stap 7, afbeelding 1 van 2 How to Fix a Papasan Chair Base: stap 7, afbeelding 2 van 2
    • Nail down one side of the rattan and re-wrap it. Finish by nailing down the other end of the rattan to secure it.
Conclusie
Following these steps will restore your papasan chair to working order.
6 andere personen hebben deze handleiding voltooid.
3 opmerkingen
What screw you used? Screw dimensions?
Lourdes Diaz - Antwoord
easy peasy…thanks
Katherine Elaine - Antwoord
Were u would u recommend get the wicker to wrap chairs , at???
Thanks in advance!!!
Carrmone Bears - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 15
Afgelopen 7 dagen: 79
Afgelopen 30 dagen: 387
Altijd: 17,771
