Ga door naar hoofdinhoud
How to Fix a Broken Toilet Paper Holder
Wat je nodig hebt
  1. How to Fix a Broken Toilet Paper Holder, How to Fix a Broken Toilet Paper Holder: stap 1, afbeelding 1 van 1
    • As you can tell, the left holder is loose. Replacing the anchor is much needed.
  2. How to Fix a Broken Toilet Paper Holder: stap 2, afbeelding 1 van 1
    • Remove the Allen screw under each holder.
    • I used a 1/6" Allen bit because that is what fit my toilet paper holder's Allen screw. Use the bit according to the screw available.
    • If the screw size is unknown, I would recommend buying a pack with several Allen bits and trying each until the right one is found.
  3. How to Fix a Broken Toilet Paper Holder: stap 3, afbeelding 1 van 3 How to Fix a Broken Toilet Paper Holder: stap 3, afbeelding 2 van 3 How to Fix a Broken Toilet Paper Holder: stap 3, afbeelding 3 van 3
    • After unscrewing the holder, take it off and begin unscrewing the screws in the wall. The type of screwdriver depends on the screws used.
    • Remove the clip after removing all screws. You should be left with two big holes and two small holes in the wall.
  4. How to Fix a Broken Toilet Paper Holder: stap 4, afbeelding 1 van 2 How to Fix a Broken Toilet Paper Holder: stap 4, afbeelding 2 van 2
    • Remove the existing anchor and drill the top hole with the 5/16" drill bit. This will make space for the new anchor to be placed.
    • Pinch the new 3/8"-1/2" anchor, place it into the top hole, and push it to be level with the wall.
  5. How to Fix a Broken Toilet Paper Holder: stap 5, afbeelding 1 van 2 How to Fix a Broken Toilet Paper Holder: stap 5, afbeelding 2 van 2
    • After placing the new anchor in, align the clip accordingly and proceed to screw in the anchor, starting with the top hole and then the bottom hole.
    • You have the option to use a either a screwdriver or drill (head based on the screws in possession).
  6. How to Fix a Broken Toilet Paper Holder: stap 6, afbeelding 1 van 2 How to Fix a Broken Toilet Paper Holder: stap 6, afbeelding 2 van 2
    • When you have completed the previous step for both sides, place the toilet paper holder in place and re-screw the Allen screw until both holders feel stiff.
Eindstreep
Andrew Nammour
181 Reputatie
1 Handleiding geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 11
Afgelopen 7 dagen: 72
Afgelopen 30 dagen: 321
Altijd: 23,533
