Ga door naar hoofdinhoud
How to Fix A Rusted Hitch
Wat je nodig hebt
  1. How to Fix A Rusted Hitch, How to Fix A Rusted Hitch: stap 1, afbeelding 1 van 1
    • This is the before picture of the rusted hitch.
  2. How to Fix A Rusted Hitch: stap 2, afbeelding 1 van 1
    • Apply the wire brush on any part of the hitch in order to brush off any excess rust or rust flakes.
  3. How to Fix A Rusted Hitch: stap 3, afbeelding 1 van 2 How to Fix A Rusted Hitch: stap 3, afbeelding 2 van 2
    • Use the small paint brush to apply a coat of naval jelly over the rusted area.
    • Allow to sit for approximately ten minutes.
    • Remember to use caution/gloves when handling the naval jelly.
  4. How to Fix A Rusted Hitch: stap 4, afbeelding 1 van 1
    • Dip the paper towel in a bowl of lukewarm water to get the paper towel damp.
  5. How to Fix A Rusted Hitch: stap 5, afbeelding 1 van 1
    • Take the wet paper towel and wipe off the naval jelly on the hitch.
  6. How to Fix A Rusted Hitch: stap 6, afbeelding 1 van 1
    • Apply a protective layer of fluid film to the treated area.
    • Spray approximately 4-6 inches away from the hitch.
  7. How to Fix A Rusted Hitch: stap 7, afbeelding 1 van 1
    • Allow the fluid film to sit for about 5 minutes.
    • You should start to see bubbling in this process.
  8. How to Fix A Rusted Hitch: stap 8, afbeelding 1 van 1
    • This is the finished, rust-free, product.
Conclusie
This procedure cannot be performed again immediately after the rust is taken off. Repeat these steps when rust develops over time.
Één andere persoon heeft deze handleiding voltooid.
Kiley Strickland
184 Reputatie
1 Handleiding geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 50
Altijd: 1,412
