Ga door naar hoofdinhoud
How to Fix A Broken Makeup Compact Without Alcohol
Wat je nodig hebt
  1. How to Fix A Broken Makeup Compact Without Alcohol, How to Fix A Broken Makeup Compact Without Alcohol: stap 1, afbeelding 1 van 1
    • Plug In the iron and turn the heat to the highest setting.
    • Caution: Be sure to place the iron on a flat, solid surface, away from plastic and other flammable objects.
  2. How to Fix A Broken Makeup Compact Without Alcohol: stap 2, afbeelding 1 van 1
    • Pour the broken powder into a plastic sandwich bag.
  3. How to Fix A Broken Makeup Compact Without Alcohol: stap 3, afbeelding 1 van 1
    • Use a spoon to break the powder down into a fine dust.
  4. How to Fix A Broken Makeup Compact Without Alcohol: stap 4, afbeelding 1 van 2 How to Fix A Broken Makeup Compact Without Alcohol: stap 4, afbeelding 2 van 2
    • Take a knife and carefully remove the metal pan from the compact.
  5. How to Fix A Broken Makeup Compact Without Alcohol: stap 5, afbeelding 1 van 3 How to Fix A Broken Makeup Compact Without Alcohol: stap 5, afbeelding 2 van 3 How to Fix A Broken Makeup Compact Without Alcohol: stap 5, afbeelding 3 van 3
    • Pour the powder into the metal pan and begin to press the powder down with the spoon.
  6. How to Fix A Broken Makeup Compact Without Alcohol: stap 6, afbeelding 1 van 3 How to Fix A Broken Makeup Compact Without Alcohol: stap 6, afbeelding 2 van 3 How to Fix A Broken Makeup Compact Without Alcohol: stap 6, afbeelding 3 van 3
    • Turn the heat off on the iron.
    • Caution: Be sure to unplug the iron.
    • Use the heat from the iron to secure the powder in the pan.
    • Press down for 15 seconds at a time.
    • Repeat as needed.
  7. How to Fix A Broken Makeup Compact Without Alcohol: stap 7, afbeelding 1 van 3 How to Fix A Broken Makeup Compact Without Alcohol: stap 7, afbeelding 2 van 3 How to Fix A Broken Makeup Compact Without Alcohol: stap 7, afbeelding 3 van 3
    • Let cool completely.
    • Place metal pan back into the compact.
    • Now the compact is ready for use.
Eindstreep
Cura Mclemore
145 Reputatie
1 Handleiding geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 18
Altijd: 180
