Ga door naar hoofdinhoud
How to Decrease the Bicep of a Sleeve
Wat je nodig hebt
  1. How to Decrease the Bicep of a Sleeve, How to Decrease the Bicep of a Sleeve: stap 1, afbeelding 1 van 3 How to Decrease the Bicep of a Sleeve, How to Decrease the Bicep of a Sleeve: stap 1, afbeelding 2 van 3 How to Decrease the Bicep of a Sleeve, How to Decrease the Bicep of a Sleeve: stap 1, afbeelding 3 van 3
    • Flip your shirt inside out.
    • The raw edges should be on the outside.
  2. How to Decrease the Bicep of a Sleeve: stap 2, afbeelding 1 van 3 How to Decrease the Bicep of a Sleeve: stap 2, afbeelding 2 van 3 How to Decrease the Bicep of a Sleeve: stap 2, afbeelding 3 van 3
    • Use a measuring tape to measure your desired width from the top point of the shoulder down to the seam of the shoulder.
    • Mark the bottom point of your measurement with a fabric pen or tailor's chalk.
  3. How to Decrease the Bicep of a Sleeve: stap 3, afbeelding 1 van 3 How to Decrease the Bicep of a Sleeve: stap 3, afbeelding 2 van 3 How to Decrease the Bicep of a Sleeve: stap 3, afbeelding 3 van 3
    • Use a fabric marker or tailor's chalk to draw a line from the marking, ensuring it aligns with the rest of the sleeve.
    • It should align with the sleeve at the cuff.
    • Draw another line from the marking, extending down to align with the side of the body of the shirt.
  4. How to Decrease the Bicep of a Sleeve: stap 4, afbeelding 1 van 3 How to Decrease the Bicep of a Sleeve: stap 4, afbeelding 2 van 3 How to Decrease the Bicep of a Sleeve: stap 4, afbeelding 3 van 3
    • Use straight pins to pin the sleeve across the lines you drew.
    • Push the pin through the top and push it back through the bottom of the sleeve.
    • Place a pin every inch across the lines.
  5. How to Decrease the Bicep of a Sleeve: stap 5, afbeelding 1 van 3 How to Decrease the Bicep of a Sleeve: stap 5, afbeelding 2 van 3 How to Decrease the Bicep of a Sleeve: stap 5, afbeelding 3 van 3
    • Using a sewing machine, sew across the pinned lines with a straight stitch.
    • Be sure to backstitch at the start and end of your stitch.
  6. How to Decrease the Bicep of a Sleeve: stap 6, afbeelding 1 van 3 How to Decrease the Bicep of a Sleeve: stap 6, afbeelding 2 van 3 How to Decrease the Bicep of a Sleeve: stap 6, afbeelding 3 van 3
    • Use scissors to cut off the excess fabric.
    • Leave a seam allowance of 6.4 mm.
  7. How to Decrease the Bicep of a Sleeve: stap 7, afbeelding 1 van 1
    • Measure again to see if you reached your desired width.
Conclusie
Now that you have finished your fix, go ahead and try on that perfect-fitting shirt. Thank you for picking this fast fix guide!
Één andere persoon heeft deze handleiding voltooid.
Elliot T
145 Reputatie
1 Handleiding geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 11
Afgelopen 30 dagen: 37
Altijd: 120
