Ga door naar hoofdinhoud
How to Clean Corroded Battery Terminals
Wat je nodig hebt
  1. How to Clean Corroded Battery Terminals, Safety precautions: stap 1, afbeelding 1 van 1
    • Wear gloves to protect your hands from the corrosion—it's a skin irritant.
    • If your device still works, power it down completely before starting.
  2. How to Clean Corroded Battery Terminals, Remove the batteries: stap 2, afbeelding 1 van 3 How to Clean Corroded Battery Terminals, Remove the batteries: stap 2, afbeelding 2 van 3 How to Clean Corroded Battery Terminals, Remove the batteries: stap 2, afbeelding 3 van 3
  3. How to Clean Corroded Battery Terminals, Remove big chunks of corrosion: stap 3, afbeelding 1 van 3 How to Clean Corroded Battery Terminals, Remove big chunks of corrosion: stap 3, afbeelding 2 van 3 How to Clean Corroded Battery Terminals, Remove big chunks of corrosion: stap 3, afbeelding 3 van 3
    • Use a toothbrush to gently remove any bigger chunks of corrosion from the battery terminals and battery recess.
    • Use the point of a spudger to pick out any bits that are stuck.
    • Pick around the batteries, and not at the batteries themselves.
    • Flip your device over and gently shake out the loose corrosion and debris.
    • Dispose of the corrosion and debris in the trash.
  4. How to Clean Corroded Battery Terminals, Remove any stuck batteries: stap 4, afbeelding 1 van 2 How to Clean Corroded Battery Terminals, Remove any stuck batteries: stap 4, afbeelding 2 van 2
    • You should now be able to remove any batteries that were previously stuck.
    • Clean out the battery recess with a toothbrush.
  5. How to Clean Corroded Battery Terminals, Clean the terminals: stap 5, afbeelding 1 van 3 How to Clean Corroded Battery Terminals, Clean the terminals: stap 5, afbeelding 2 van 3 How to Clean Corroded Battery Terminals, Clean the terminals: stap 5, afbeelding 3 van 3
    • Alkaline batteries contain a base, which is what corrosion is made of. An acid like white vinegar or lemon juice will neutralize this base.
    • Lightly dip a cotton swab in white vinegar or lemon juice.
    • Don't soak the cotton swab. Only use a small amount of liquid at a time.
    • Gently rub the battery terminals with the cotton swab to dissolve and remove the corrosion.
    • The corrosion may fizz and bubble. Don't worry, this is normal.
    • Continue this process until there's no corrosion on the terminals.
  6. How to Clean Corroded Battery Terminals: stap 6, afbeelding 1 van 3 How to Clean Corroded Battery Terminals: stap 6, afbeelding 2 van 3 How to Clean Corroded Battery Terminals: stap 6, afbeelding 3 van 3
    Gereedschap gebruikt in deze stap:
    Microfiber Cleaning Cloths
    $3.99
    Koop
    • Isopropyl alcohol will remove any residue left from the previous step.
    • Lightly dip a cotton swab in highly-concentrated isopropyl alcohol (over 90%).
    • Gently rub the battery terminals with the cotton swap to remove any remaining residue from the previous step.
    • Wipe the residue away with a microfiber or lint-free cloth.
    • Repeat this process until the terminals are completely clean.
    • Wait two minutes to allow any residual alcohol to evaporate.
  7. How to Clean Corroded Battery Terminals, Install new batteries: stap 7, afbeelding 1 van 3 How to Clean Corroded Battery Terminals, Install new batteries: stap 7, afbeelding 2 van 3 How to Clean Corroded Battery Terminals, Install new batteries: stap 7, afbeelding 3 van 3
Conclusie
Cleaning didn’t go as planned? Ask our Answers community for help.
For other electronics skills, click here.
Spencer Day
58.587 Reputatie
430 handleidingen geschreven
iFixit Lid van iFixit
Staff
137 Leden
17.523 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 58
Afgelopen 7 dagen: 359
Afgelopen 30 dagen: 1,348
Altijd: 5,985
