Ga door naar hoofdinhoud
Handspring Visor Edge Speaker Replacement
Wat je nodig hebt
  1. Handspring Visor Edge Speaker Replacement, Flip Cover: stap 1, afbeelding 1 van 2 Handspring Visor Edge Speaker Replacement, Flip Cover: stap 1, afbeelding 2 van 2
    • Open the Visor Edge and place it on a table facing down.
    • Gently push the tab that connects the flip cover (top half) to the PDA (bottom half) upward, lift the pieces apart to detach them.
    • Do not pull on the flip cover in an attempt to remove it from the PDA.
  2. Handspring Visor Edge Speaker Replacement, Back Panel: stap 2, afbeelding 1 van 1
    • Remove the six 4.1 mm Phillips screws from the back plate using the #00 Phillips Scewdriver.
  3. Handspring Visor Edge Speaker Replacement: stap 3, afbeelding 1 van 1
    • Remove the gray back plate from the PDA.
  4. Handspring Visor Edge Speaker Replacement: stap 4, afbeelding 1 van 2 Handspring Visor Edge Speaker Replacement: stap 4, afbeelding 2 van 2
    • Remove the four 2.6 mm Philips screws that are on the sides of the frame.
    • Remove the 3.9 mm Philips screw holding the stylus holster to the frame.
  5. Handspring Visor Edge Speaker Replacement: stap 5, afbeelding 1 van 2 Handspring Visor Edge Speaker Replacement: stap 5, afbeelding 2 van 2
    • Remove the four 2.6 mm Philips screws on the top and bottom of the frame.
  6. Handspring Visor Edge Speaker Replacement: stap 6, afbeelding 1 van 1
    • Gently remove the white frame from the back of the PDA.
  7. Handspring Visor Edge Speaker Replacement, Speaker: stap 7, afbeelding 1 van 1
    • Gently pull off front cover.
  8. Handspring Visor Edge Speaker Replacement: stap 8, afbeelding 1 van 1
    • Gently remove buttons by hand.
  9. Handspring Visor Edge Speaker Replacement: stap 9, afbeelding 1 van 1
    • Pull off button board.
    • (The button board is located underneath the buttons).
  10. Handspring Visor Edge Speaker Replacement: stap 10, afbeelding 1 van 1
    Gereedschap gebruikt in deze stap:
    Koop
    • Carefully remove the speaker by pulling on the body of the plug with a pair of tweezers, rocking it from side to side to ease it if necessary.
    • Pull in the same direction as the individual wires are running and make sure to evenly on the full width of the cable so that no individual wires are overly strained.
Conclusie
Nick Lazarakis
331 Reputatie
3 handleidingen geschreven
Cal Poly, Team 11-28, Maness Winter 2011 Lid van Cal Poly, Team 11-28, Maness Winter 2011
CPSU-MANESS-W11S11G28
4 Leden
7 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 4
Altijd: 806
