Ga door naar hoofdinhoud
HTC Desire 816 Camera Replacement
Wat je nodig hebt
  1. HTC Desire 816 Camera Replacement, Battery: stap 1, afbeelding 1 van 1
    • Pry open the back panel by inserting the plastic opening tool on the left of the camera. We find this spot the easiest to get the tool under the panel.
  2. HTC Desire 816 Camera Replacement: stap 2, afbeelding 1 van 1
    • Once you get an open spot, with a second plastic opening tool, slide down to the bottom of the phone to free the rest of side.
  3. HTC Desire 816 Camera Replacement: stap 3, afbeelding 1 van 1
    • There is adhesive between the battery and the back panel. Take a nylon spudger to cut through the adhesive.
    • Be sure to use the correct tool for the job. Metal spudgers can puncture an unprotected battery, potentially causing a fire.
  4. HTC Desire 816 Camera Replacement: stap 4, afbeelding 1 van 1
    • Once all way around the bottom, the panel should be broken free of the adhesive, and the rest of the panel should pop right off.
  5. HTC Desire 816 Camera Replacement: stap 5, afbeelding 1 van 1
    • Insert a nylon spudger at the bottom of the battery and lift up to remove the battery.
  6. HTC Desire 816 Camera Replacement: stap 6, afbeelding 1 van 1
    • There is adhesive on the other side of the battery as well, take the nylon spudger used to get off the panel and cut through.
  7. HTC Desire 816 Camera Replacement: stap 7, afbeelding 1 van 1
    • Carefully lift battery backside first to disconnect the white connector.
  8. HTC Desire 816 Camera Replacement, Back Facing Camera: stap 8, afbeelding 1 van 1
    • Take the T5 screwdriver head to take out these 4 screws
  9. HTC Desire 816 Camera Replacement: stap 9, afbeelding 1 van 1
    • Remove the black plastic casing with a plastic opening tool.
  10. HTC Desire 816 Camera Replacement: stap 10, afbeelding 1 van 1
    • Take the PH000 screwdriver head to take out the one screw that's holding down the green panel. (The screw is located on the left side of the panel)
  11. HTC Desire 816 Camera Replacement: stap 11, afbeelding 1 van 1
    Gereedschap gebruikt in deze stap:
    Koop
    • With your pair of tweezers carefully unplug the black and red wire in order to remove the motherboard
  12. HTC Desire 816 Camera Replacement: stap 12, afbeelding 1 van 1
    • Once you have removed the wire, you can carefully lift up the motherboard
  13. HTC Desire 816 Camera Replacement: stap 13, afbeelding 1 van 1
    • Peel off the yellow film that’s attaching the camera to the motherboard
  14. HTC Desire 816 Camera Replacement: stap 14, afbeelding 1 van 1
    • Slowly lift up the white connector so that the camera’s cable may properly be detached.
  15. HTC Desire 816 Camera Replacement: stap 15, afbeelding 1 van 1
    • Carefully peel off the adhesive so that the camera can be disconnected from the mother board
Conclusie
4 andere personen hebben deze handleiding voltooid.
Saleena Douangphachanh
612 Reputatie
5 handleidingen geschreven
UMass Dartmouth, Team 5-3, Landers Spring 2016 Lid van UMass Dartmouth, Team 5-3, Landers Spring 2016
UMASSD-LANDERS-S16S5G3
3 Leden
12 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 12
Altijd: 2,564
