Ga door naar hoofdinhoud
HP iPAQ h4155 button panel replacement
Wat je nodig hebt
  1. HP iPAQ h4155 button panel replacement, Battery: stap 1, afbeelding 1 van 1
    • While sliding the silver release tab up, simultaneously lift the cover up from the left side.
  2. HP iPAQ h4155 button panel replacement: stap 2, afbeelding 1 van 1
    • Push the tab left to right to remove the cover.
  3. HP iPAQ h4155 button panel replacement: stap 3, afbeelding 1 van 1
    • Now, lift the battery up and away from the device to remove it.
  4. HP iPAQ h4155 button panel replacement, Back Case: stap 4, afbeelding 1 van 1
    • Remove the four silver screws using the T5 Torx Screwdriver (T5 x .25 in).
  5. HP iPAQ h4155 button panel replacement: stap 5, afbeelding 1 van 1
    • Remove the single black screw that is located beneath the HP sticker with the T5 Torx Screwdriver.
  6. HP iPAQ h4155 button panel replacement: stap 6, afbeelding 1 van 2 HP iPAQ h4155 button panel replacement: stap 6, afbeelding 2 van 2
    • Next, use your plastic removal tool to separate the gray back from the black center piece.
    • For better results, start the separation at the corner piece.
  7. HP iPAQ h4155 button panel replacement: stap 7, afbeelding 1 van 1
    • Remove the back case.
  8. HP iPAQ h4155 button panel replacement, Face Plate: stap 8, afbeelding 1 van 1
    • Now that the back cover is removed, use the #00 Philips x .17 screwdriver to remove the small screw to the left of the SD card slot.
  9. HP iPAQ h4155 button panel replacement: stap 9, afbeelding 1 van 2 HP iPAQ h4155 button panel replacement: stap 9, afbeelding 2 van 2
    Gereedschap gebruikt in deze stap:
    Koop
    • Next, unlock and remove the ribbon cable.
    • Using metal tweezers, carefully pull back on both sides of the brown bar unlocking the cable and slipping it out of the connector.
    • The bar, the connector, and the cable are fragile components that are easily broken.
  10. HP iPAQ h4155 button panel replacement: stap 10, afbeelding 1 van 2 HP iPAQ h4155 button panel replacement: stap 10, afbeelding 2 van 2
    • Next, remove the wire from the bottom of the mother board.
    • The easiest method is to use metal tweezers and grip the plug closest to the connector.
    • Make sure all the connections are properly disconnected before separation from the motherboard.
  11. HP iPAQ h4155 button panel replacement: stap 11, afbeelding 1 van 1
    • Next, use a plastic removal tool and separate the silver front case from the black frame.
  12. HP iPAQ h4155 button panel replacement, JoyPad buttons: stap 12, afbeelding 1 van 1
    • Remove the 4 screws along the bottom of the faceplate
    • They are #00 Philips head screws
  13. HP iPAQ h4155 button panel replacement: stap 13, afbeelding 1 van 2 HP iPAQ h4155 button panel replacement: stap 13, afbeelding 2 van 2
    • Once removed you can easily separate the keys from the body.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
John Pagliero
942 Reputatie
7 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 6
Altijd: 457
