Ga door naar hoofdinhoud
HP Pavilion dv6000 Speaker Bar Replacement
Wat je nodig hebt
  1. HP Pavilion dv6000 Speaker Bar Replacement, Speaker Bar: stap 1, afbeelding 1 van 1
    • Make sure the laptop lid is closed, turn it over and remove the battery by moving the switch right to left.
    • there are three philips screws located on the surface where the writing is. remove those three screws.
  2. HP Pavilion dv6000 Speaker Bar Replacement: stap 2, afbeelding 1 van 1
    • turn the laptop right side up. Between the cover and case on the top right of the laptop and using a plastic sludger or a finger lift gently on the speaker cover as to disengage the clips.
    • Be sure not to pull hard or you may damage the ribbon cables.
    • From the side closest to the screen turn the cover towards yourself.
  3. HP Pavilion dv6000 Speaker Bar Replacement: stap 3, afbeelding 1 van 1
    • there is one connector from the speaker bar to a control board. Gently remove the cable.
    • There are two more screws attaching the speaker bar to the cover, remove these and take the speaker bar out.
  4. HP Pavilion dv6000 Speaker Bar Replacement: stap 4, afbeelding 1 van 1
    • you are now ready to replace or repair the speaker bar. I recomend purchasing a new one, they range anywhere from 5-15 dollars online.
Conclusie
5 andere personen hebben deze handleiding voltooid.
Joba Fett
227 Reputatie
1 Handleiding geschreven
2 opmerkingen
how to fix speaker from board
kingsley Osunkwo - Antwoord
Grazie siete bravissimi . Ce ne fossero persone come voi che altruisticamente mettono a disposizione la loro esperienza di riparazioni per gli altri!
Fernando Mancini
fernando mancini - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 14
Altijd: 3,461
