Ga door naar hoofdinhoud
HP Pavilion dv6000 RAM Replacement
Wat je nodig hebt
  1. HP Pavilion dv6000 RAM Replacement, RAM: stap 1, afbeelding 1 van 3 HP Pavilion dv6000 RAM Replacement, RAM: stap 1, afbeelding 2 van 3 HP Pavilion dv6000 RAM Replacement, RAM: stap 1, afbeelding 3 van 3
    • Remove the two screws from the memory shield and lift up. The screws will remain into the shield
  2. HP Pavilion dv6000 RAM Replacement: stap 2, afbeelding 1 van 3 HP Pavilion dv6000 RAM Replacement: stap 2, afbeelding 2 van 3 HP Pavilion dv6000 RAM Replacement: stap 2, afbeelding 3 van 3
    • Using a plastic spudger depress the pins holding the RAM in. If you have an anti-static work surface or wristband, you may suppress the pins with your thumbs.
    • Static charge built up on surfaces contacting the RAM or other computer components can damage and destroy the components. Always discharge yourself before handling these components!
    • Pull the RAM straight out.
  3. HP Pavilion dv6000 RAM Replacement: stap 3, afbeelding 1 van 1
    • Under the first RAM stick is another. Remove it in the same way by pushing the silver tabs away and down from the RAM stick and remove the RAM once it pops up.
  4. HP Pavilion dv6000 RAM Replacement: stap 4, afbeelding 1 van 1
    • You have removed your RAM!
    • If you want to expand your RAM you will have to use DDR2 PC2-5300 SODIMM laptop memory modules, they are clocked at 667MHz
    • To reinstall your RAM, follow this guide in the reverse order
Conclusie
18 andere personen hebben deze handleiding voltooid.
Ben Hirsch
3.826 Reputatie
10 handleidingen geschreven
Cal Poly, Team 21-33, Regan Fall 2010 Lid van Cal Poly, Team 21-33, Regan Fall 2010
CPSU-REGAN-F10S21G33
4 Leden
12 handleidingen geschreven
3 opmerkingen
if you have bios version f.25 or newer you can have up to 4gb of ram
Bryce Stidman - Antwoord
2+2 or 4+4 ? which one?
Jes White -
That is pretty helpful. I think I am going to update my bios, not to mention the article forgot to mention to have a DDR2 ram. Just make sure to look for a DDR2 PC2- 5300 version with 667 MHz.
Tommy E. -
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 52
Altijd: 34,772
