Ga door naar hoofdinhoud
HP 15-dy2702dx Battery Replacement
Wat je nodig hebt
  1. HP 15-dy2702dx Battery Replacement, Lower Case: stap 1, afbeelding 1 van 1
    • Remove both of the rubber strips to uncover the hidden screws.
    • You can use a prying tool to help lift an end.
  2. HP 15-dy2702dx Battery Replacement: stap 2, afbeelding 1 van 1
    • Unscrew all 8 Phillips #0 screws on the bottom panel:
    • Two M2.5x6
    • Six M2x6
  3. HP 15-dy2702dx Battery Replacement: stap 3, afbeelding 1 van 2 HP 15-dy2702dx Battery Replacement: stap 3, afbeelding 2 van 2
    • Flip the laptop over and open the lid.
    • Separate the bottom panel from the main body by using the iFixit opening tool.
    • Ensure that the bottom panel is completely separated along the edges.
  4. HP 15-dy2702dx Battery Replacement: stap 4, afbeelding 1 van 2 HP 15-dy2702dx Battery Replacement: stap 4, afbeelding 2 van 2
    • If you can lift the laptop like shown in the first picture, the bottom panel is nearly separated.
    • Close the laptop to allow the back edges to fully separate
  5. HP 15-dy2702dx Battery Replacement: stap 5, afbeelding 1 van 3 HP 15-dy2702dx Battery Replacement: stap 5, afbeelding 2 van 3 HP 15-dy2702dx Battery Replacement: stap 5, afbeelding 3 van 3
    • Flip the laptop over and carefully remove the lower case.
  6. HP 15-dy2702dx Battery Replacement, Battery: stap 6, afbeelding 1 van 2 HP 15-dy2702dx Battery Replacement, Battery: stap 6, afbeelding 2 van 2
    • Remove the five M2x6 screws that secure the battery with a Phillips #0 screwdriver.
  7. HP 15-dy2702dx Battery Replacement: stap 7, afbeelding 1 van 3 HP 15-dy2702dx Battery Replacement: stap 7, afbeelding 2 van 3 HP 15-dy2702dx Battery Replacement: stap 7, afbeelding 3 van 3
    • Grab the sides of the battery and gently pull the battery until it disconnects from the connector on motherboard.
    • Lift the battery up and out.
Conclusie
September Oo
397 Reputatie
4 handleidingen geschreven
Gateway, Team 1-4, Pee Fall 2023 Lid van Gateway, Team 1-4, Pee Fall 2023
GCC-PEE-F23S1G4
4 Leden
8 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 9
Afgelopen 30 dagen: 50
Altijd: 263
