Ga door naar hoofdinhoud
Game Boy Advance Back Panel Replacement
Wat je nodig hebt
Video overzicht
  1. Game Boy Advance Back Panel Replacement, Remove the Battery Cover/Batteries: stap 1, afbeelding 1 van 3 Game Boy Advance Back Panel Replacement, Remove the Battery Cover/Batteries: stap 1, afbeelding 2 van 3 Game Boy Advance Back Panel Replacement, Remove the Battery Cover/Batteries: stap 1, afbeelding 3 van 3
    • Take the battery cover off by releasing the locking tab and hinging the cover away. Remove the batteries inside the cover
    • Do not forget to remove the batteries! This applies to working with any electronic device as working with live electricity may damage the device or cause malfunctions
  2. Game Boy Advance Back Panel Replacement, Unscrew the Back Panel: stap 2, afbeelding 1 van 2 Game Boy Advance Back Panel Replacement, Unscrew the Back Panel: stap 2, afbeelding 2 van 2
    • Remove the six back panel screws using a Tri-wing Screwdriver.
    • Remove bottom back panel screw with a Phillips #1 screw driver. (Image #2)
  3. Game Boy Advance Back Panel Replacement, Remove the Back Panel: stap 3, afbeelding 1 van 1
    • Remove the back panel by pulling away with one hand and the front secured in the other hand.
    • Removal of the back panel may cause shoulder buttons and side panels to come loose and fall off.
Conclusie
4 andere personen hebben deze handleiding voltooid.
Aldo Corona
799 Reputatie
6 handleidingen geschreven
Cal Poly, Team 16-29, Maness Winter 2010 Lid van Cal Poly, Team 16-29, Maness Winter 2010
CPSU-MANESS-W10S16G29
5 Leden
61 handleidingen geschreven
Één opmerking
Seeing the GBA-SP guide, could information here be added so we know which mm triwing screws the regular GBA backpanel uses?
Renzo Guichelaar - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 20
Afgelopen 30 dagen: 90
Altijd: 10,573
