Ga door naar hoofdinhoud
Fujitsu Lifebook Stylistic Q584 Speakers Replacement
Wat je nodig hebt
  1. Fujitsu Lifebook Stylistic Q584 Speakers Replacement, Back Case: stap 1, afbeelding 1 van 1
    • Remove the white sticker covering the screws (if applicable).
    • Use the PH1 screwdriver to remove the four 2 mm screws from the the backside of the device.
  2. Fujitsu Lifebook Stylistic Q584 Speakers Replacement: stap 2, afbeelding 1 van 1
    • Insert the plastic opening tool along the seam of the back case.
    • Gently slide the plastic opening tool along the entire seam popping the clips free.
  3. Fujitsu Lifebook Stylistic Q584 Speakers Replacement: stap 3, afbeelding 1 van 1
    • Carefully lift the back case and remove the smartcard ribbon from the motherboard.
  4. Fujitsu Lifebook Stylistic Q584 Speakers Replacement, Inner Back Shield: stap 4, afbeelding 1 van 1
    • Remove the ten 3mm screws with a PH00 screwdriver from the shield.
  5. Fujitsu Lifebook Stylistic Q584 Speakers Replacement: stap 5, afbeelding 1 van 1
    • Remove the grey docking station port cover.
  6. Fujitsu Lifebook Stylistic Q584 Speakers Replacement: stap 6, afbeelding 1 van 1
  7. Fujitsu Lifebook Stylistic Q584 Speakers Replacement: stap 7, afbeelding 1 van 1
    • Lift the shield away from the device and remove the fingerprint scanner's ribbon from the motherboard.
  8. Fujitsu Lifebook Stylistic Q584 Speakers Replacement, Speakers: stap 8, afbeelding 1 van 1
    • Pull up the cord that connects the battery to the motherboard
  9. Fujitsu Lifebook Stylistic Q584 Speakers Replacement: stap 9, afbeelding 1 van 2 Fujitsu Lifebook Stylistic Q584 Speakers Replacement: stap 9, afbeelding 2 van 2
    • Use the narrow plastic opening tool to pry the speakers from the casing.
  10. Fujitsu Lifebook Stylistic Q584 Speakers Replacement: stap 10, afbeelding 1 van 1
    • Unplug the speaker wires from the motherboard.
Conclusie
Connor Stanton
613 Reputatie
6 handleidingen geschreven
Één opmerking
Hello,
Thanks for this guide.
Is the ssd storage card replaceable on the q584.
I want to put a 256gb card internally.
Also, I notice a slot where the 4G /LTE modem goes.
Do you know the part number of that addition.
Thanks
Vince - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 9
Altijd: 474
