Inleiding
It is not common knowledge to replace the filter in a fan coil system despite the fact that it may seem so to others. This guide will ensure that you are able to replace the existing filter in your fan coil system in a quick and effective manner. People will spend money to have someone come in and repair their fan coil due to damage caused by dust and residue build-up on the filter. Meanwhile, this damage can be avoided altogether by regular filter changes. A fan coil filter should be replaced every 2-3 months to ensure clean air quality in the household.
Wat je nodig hebt
Clean the fan coil grilles using a paper towel and water.
Following these steps, you will be able to replace the filter in your fan coil system.
