Ga door naar hoofdinhoud
Eyelash Extensions Replacement
Wat je nodig hebt
  1. Eyelash Extensions Replacement, Eyelash Extensions: stap 1, afbeelding 1 van 1
    • Wash hands thoroughly and make sure that the station and tools are cleaned and disinfected.
  2. Eyelash Extensions Replacement: stap 2, afbeelding 1 van 1
    • Place the medical-grade tape under each eye, making sure that all the lower lashes are secured.
  3. Eyelash Extensions Replacement: stap 3, afbeelding 1 van 1
    • Make sure that the client feels comfortable with the tape on with their eyes closed.
  4. Eyelash Extensions Replacement: stap 4, afbeelding 1 van 1
    • Brush the eyelashes thoroughly using a mascara wand to remove the eyelashes that are ready to shed.
  5. Eyelash Extensions Replacement: stap 5, afbeelding 1 van 2 Eyelash Extensions Replacement: stap 5, afbeelding 2 van 2
    Gereedschap gebruikt in deze stap:
    Koop
    • Remove all the grown-out lashes using the banana peel method.
    • Hold the natural lash in one clean tweezer and the eyelash extension in the other set of clean tweezers.
    • Gently pull the natural lash and the lash extension in opposite directions and peel the lashes apart like a banana.
  6. Eyelash Extensions Replacement: stap 6, afbeelding 1 van 1
    • Brush the eyelashes again using a mascara wand after removing all the grown-out lashes.
  7. Eyelash Extensions Replacement: stap 7, afbeelding 1 van 3 Eyelash Extensions Replacement: stap 7, afbeelding 2 van 3 Eyelash Extensions Replacement: stap 7, afbeelding 3 van 3
    • Put a drop or two of the eyelash primer on the micro swabs.
    • Dab the micro swabs on the eyelashes while making sure that it does not touch the eyelids as it can sting the client’s eyes.
  8. Eyelash Extensions Replacement: stap 8, afbeelding 1 van 1
    • Let it air dry or use a fan for a faster dry time.
  9. Eyelash Extensions Replacement: stap 9, afbeelding 1 van 1
    • Place a new lash extension using the eyelash extension adhesive of choice onto the natural eyelash, making sure that the eyelashes are isolated.
  10. Eyelash Extensions Replacement: stap 10, afbeelding 1 van 2 Eyelash Extensions Replacement: stap 10, afbeelding 2 van 2
    • Repeat Step 9 for both eyes until you are completely satisfied with your work.
  11. Eyelash Extensions Replacement: stap 11, afbeelding 1 van 1
    • Inspect, separate, and brush the lashes to make sure that there are no upper lashes stuck on the lower lashes.
  12. Eyelash Extensions Replacement: stap 12, afbeelding 1 van 1
    • Use a fan for 5-10 minutes to make sure that the adhesive is cured.
  13. Eyelash Extensions Replacement: stap 13, afbeelding 1 van 1
    • Gently remove the tape from under each eye.
Eindstreep
April Pantaleon
349 Reputatie
2 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 15
Altijd: 332
