Ga door naar hoofdinhoud
Dell Inspiron 17 Laptop Battery Replacement
Wat je nodig hebt
  1. Dell Inspiron 17 Laptop Battery Replacement, Battery: stap 1, afbeelding 1 van 1
    • Before starting, make sure the laptop is powered off and disconnected from any power sources.
  2. Dell Inspiron 17 Laptop Battery Replacement: stap 2, afbeelding 1 van 1
    • Remove the Screws of the Laptop with help screwdriver.
    • There are 6 screws to remove. Make Sure to open the back of the laptop delicately.
  3. Dell Inspiron 17 Laptop Battery Replacement: stap 3, afbeelding 1 van 1
    • Carefully disconnect the old battery from the motherboard.
    • Gently remove the old battery from its housing by removing plug of battery.
  4. Dell Inspiron 17 Laptop Battery Replacement: stap 4, afbeelding 1 van 1
    • Insert the new battery into the housing.
    • Connect the new battery to the motherboard.
    • Securely reattach the battery back cover.
  5. Dell Inspiron 17 Laptop Battery Replacement: stap 5, afbeelding 1 van 1
    • Plug in the laptop and charge it to Full Capacity.
    • Power on the laptop and make sure it works with the new battery.
Conclusie
Anmol Desai
178 Reputatie
1 Handleiding geschreven
York University, Team 2-7, O'Regan Fall 2023 Lid van York University, Team 2-7, O'Regan Fall 2023
YORK-O'REGAN-F23S2G7
1 Lid
2 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 9
Afgelopen 7 dagen: 61
Afgelopen 30 dagen: 299
Altijd: 1,069
