Ga door naar hoofdinhoud
Daewoo DWC LDC1412S Water pump replacement Replacement
Wat je nodig hebt
  1. Daewoo DWC LDC1412S Water pump replacement Replacement, Water pump replacement: stap 1, afbeelding 1 van 1
    • Turn the washing machine on it s back
  2. Daewoo DWC LDC1412S Water pump replacement Replacement: stap 2, afbeelding 1 van 2 Daewoo DWC LDC1412S Water pump replacement Replacement: stap 2, afbeelding 2 van 2
    • Unscrew the 2 screw that keep the pump in place
    • You can now gently tear down the pump
  3. Daewoo DWC LDC1412S Water pump replacement Replacement: stap 3, afbeelding 1 van 1
    • Compare your actual pump with the spare you found BEFORE dismounting pipes !
    • Seems ok ? Let s go forward !
  4. Daewoo DWC LDC1412S Water pump replacement Replacement: stap 4, afbeelding 1 van 2 Daewoo DWC LDC1412S Water pump replacement Replacement: stap 4, afbeelding 2 van 2
    • Dismount pipes by pressing steel rings and moving then out of range of the pump
    • Do this for all pipes connected on the pump
  5. Daewoo DWC LDC1412S Water pump replacement Replacement: stap 5, afbeelding 1 van 1
    • Pipes are now disconnected. Let's go for electrical connections
  6. Daewoo DWC LDC1412S Water pump replacement Replacement: stap 6, afbeelding 1 van 1
    • Disconnect both electro pump. Check were is white wire and black wire on each !!
  7. Daewoo DWC LDC1412S Water pump replacement Replacement: stap 7, afbeelding 1 van 1
    • Move last evacuation pipe on the new part
    • ...you can know mount the new part and try your new pump !!
Conclusie
hellotheworld
191 Reputatie
1 Handleiding geschreven
Één opmerking
Thanks, this saved me heaps of money!!!
Brendan Innes - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 26
Afgelopen 30 dagen: 78
Altijd: 3,668
