Ga door naar hoofdinhoud
Casio Cassiopeia E-125 Touch Screen Replacement
Wat je nodig hebt
  1. Casio Cassiopeia E-125 Touch Screen Replacement, Battery: stap 1, afbeelding 1 van 1
    • Flip the device over to the back side.
  2. Casio Cassiopeia E-125 Touch Screen Replacement: stap 2, afbeelding 1 van 1
    • Slide the small switch on the back to "MAIN".
  3. Casio Cassiopeia E-125 Touch Screen Replacement: stap 3, afbeelding 1 van 1
    • Slide the battery cover downwards.
    • Pull off the battery cover.
  4. Casio Cassiopeia E-125 Touch Screen Replacement: stap 4, afbeelding 1 van 1
    • Pull the black tab to remove the battery.
  5. Casio Cassiopeia E-125 Touch Screen Replacement, Touch Screen: stap 5, afbeelding 1 van 1
    • Use the Phillips #00 screwdriver to remove the two screws near the top of the device.
  6. Casio Cassiopeia E-125 Touch Screen Replacement: stap 6, afbeelding 1 van 1
    • Use the Phillips #00 screwdriver to remove the two screws located inside the battery compartment.
  7. Casio Cassiopeia E-125 Touch Screen Replacement: stap 7, afbeelding 1 van 1
    • Use a spudger or opening tool to separate the two halves of the case.
  8. Casio Cassiopeia E-125 Touch Screen Replacement: stap 8, afbeelding 1 van 1
    • Pry the two halves of the case apart with the opening tool.
  9. Casio Cassiopeia E-125 Touch Screen Replacement: stap 9, afbeelding 1 van 1
    • Potential for device damage. Do not pull apart the wires connecting the outer case.
    • Lay the two halves of the outer case next to the central components as shown.
  10. Casio Cassiopeia E-125 Touch Screen Replacement: stap 10, afbeelding 1 van 1
    • Use the Philips #00 screwdriver to remove the three screws in the corners of the screen.
  11. Casio Cassiopeia E-125 Touch Screen Replacement: stap 11, afbeelding 1 van 2 Casio Cassiopeia E-125 Touch Screen Replacement: stap 11, afbeelding 2 van 2
    • Lift the tab on the motherboard and pull out the ribbon cable.
    • After the ribbon cable is detached from the motherboard, the touch screen is completely separated from the device.
Conclusie
Ryan Fernandez
47 Reputatie
5 handleidingen geschreven
Cal Poly, Team 5-4, Forte Spring 2012 Lid van Cal Poly, Team 5-4, Forte Spring 2012
CPSU-FORTE-S12S5G4
6 Leden
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 12
Altijd: 1,012
