Ga door naar hoofdinhoud
Cabin air filter replacement for a SEAT Cordoba II (2002-2009)
Wat je nodig hebt
  1. Cabin air filter replacement for a SEAT Cordoba II (2002-2009), Locating the filter: stap 1, afbeelding 1 van 2 Cabin air filter replacement for a SEAT Cordoba II (2002-2009), Locating the filter: stap 1, afbeelding 2 van 2
    • The cabin air filter is located in the passenger side footwell
  2. Cabin air filter replacement for a SEAT Cordoba II (2002-2009), Removing the cover: stap 2, afbeelding 1 van 3 Cabin air filter replacement for a SEAT Cordoba II (2002-2009), Removing the cover: stap 2, afbeelding 2 van 3 Cabin air filter replacement for a SEAT Cordoba II (2002-2009), Removing the cover: stap 2, afbeelding 3 van 3
    • Remove the cover by loosening the four screws that hold it in place, keeping track of where they go to replace them in the some holes.
    • Once that the screws are removed, the cover will come down.
  3. Cabin air filter replacement for a SEAT Cordoba II (2002-2009), Removing the filter: stap 3, afbeelding 1 van 3 Cabin air filter replacement for a SEAT Cordoba II (2002-2009), Removing the filter: stap 3, afbeelding 2 van 3 Cabin air filter replacement for a SEAT Cordoba II (2002-2009), Removing the filter: stap 3, afbeelding 3 van 3
    • Now with more room to remove it, slide the two plastic tabs together.
    • When the two plastic tabs are in the middle pull the filter cover down.
  4. Cabin air filter replacement for a SEAT Cordoba II (2002-2009), Removing the filter II: stap 4, afbeelding 1 van 2 Cabin air filter replacement for a SEAT Cordoba II (2002-2009), Removing the filter II: stap 4, afbeelding 2 van 2
    • Remove the filter.
    • Once you remove the filter make sure to notice the direction of the air-flow arrows so that you install the new one in the same direction.
  5. Cabin air filter replacement for a SEAT Cordoba II (2002-2009), Re-assembly: stap 5, afbeelding 1 van 1
    • To install the new filter follow the previous steps in reverse. If the filter and the plastic cover don't install fully, it is possible that it is installed backwards.
    • When re-installing the cover re-insert the tab and push upwards. Then reinstall the screws.
Eindstreep
5 andere personen hebben deze handleiding voltooid.
Met dank aan deze vertalers:
es en
100%
WhoDat? helpt ons de wereld te herstellen! Wil je bijdragen?
Begin met vertalen ›
Jonatan M
530 Reputatie
2 handleidingen geschreven
Één opmerking
me agremio para conocer formas de reparar yo mismo y economisar el presupuesto mensual
oscar ibarra - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 15
Afgelopen 7 dagen: 132
Afgelopen 30 dagen: 307
Altijd: 7,322
