Inleiding
Whether you're a beginner or an experienced at sewing it's essential to know how to properly install a needle to ensure smooth and accurate stitching. Here's a step-by-step guide on how to fix a needle on a sewing machine.
Wat je nodig hebt
Locate the screw and turn the screw counterclockwise (left).
Loosen the screw gently and carefully remove the needle.
In conclusion, fixing a needle on a sewing machine is a fundamental skill for any person using a sewing machine. By following a few simple steps, you can ensure that the needle is securely and correctly positioned, leading to smooth and accurate stitching.
