Ga door naar hoofdinhoud
Bomann DB 774CB Iron
Wat je nodig hebt
  1. Bomann DB 774CB Iron, Startup: stap 1, afbeelding 1 van 1
    • Locate and extract the small plug (circled in the photo) and remove the screw hidden underneath.
    • Unscrew and remove the back plate.
  2. Bomann DB 774CB Iron, Undressing the handle: stap 2, afbeelding 1 van 3 Bomann DB 774CB Iron, Undressing the handle: stap 2, afbeelding 2 van 3 Bomann DB 774CB Iron, Undressing the handle: stap 2, afbeelding 3 van 3
    • Unclip the top of the handle from the back (clips circled in the photos).
    • Unclip the top of the handle from the front (clips circled in the photo). Be careful not to break (like us) the steam nozzle!
    • Pull out the steam control knobs.
    • Carefully "tear" the temperature adjustment knob.
  3. Bomann DB 774CB Iron, Stripping of the sole: stap 3, afbeelding 1 van 2 Bomann DB 774CB Iron, Stripping of the sole: stap 3, afbeelding 2 van 2
    • Remove the screws and remove the plastic shell.
    • Unscrew the screws and remove the base cover.
  4. Bomann DB 774CB Iron, Breakdowns: stap 4, afbeelding 1 van 1
    • Two different failures already observed:
    • Spacer (circled) which had come out of its housing following a fall of the iron!
    • Small foreign body that got stuck between the two contacts (circled).
    • Be careful not to turn the temperature adjustment screw (arrow) located in the control rod. Its readjustment is quite tedious, by mistake and trials!
Conclusie
Putting each screw back in its place is no problem.
6 andere personen hebben deze handleiding voltooid.
Met dank aan deze vertalers:
fr en
100%
HelloMacOS helpt ons de wereld te herstellen! Wil je bijdragen?
Begin met vertalen ›
Louis Possoz
435 Reputatie
3 handleidingen geschreven
Repair Café Louvain-la-Neuve Lid van Repair Café Louvain-la-Neuve
Local Repair Groups
2 Leden
6 handleidingen geschreven
Één opmerking
Do you instructions in English
Nur Haque - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 13
Afgelopen 30 dagen: 39
Altijd: 2,999
