Ga door naar hoofdinhoud
Apple Studio Display M7649 Rear Panel Replacement
Wat je nodig hebt
  1. Apple Studio Display M7649 Rear Panel Replacement, Stand: stap 1, afbeelding 1 van 2 Apple Studio Display M7649 Rear Panel Replacement, Stand: stap 1, afbeelding 2 van 2
    • Lay the display facing down with the stand away from you.
    • Remove the three size 2.0 hex screws on the swing arm and remove the swing arm as well as the plastic shield under it.
  2. Apple Studio Display M7649 Rear Panel Replacement, Panels: stap 2, afbeelding 1 van 1
    • Remove the size 2.5 hex screws from each corner that connects the panels to the display and remove them.
  3. Apple Studio Display M7649 Rear Panel Replacement: stap 3, afbeelding 1 van 1
    • Rotate the display so the legs of the display are now facing you
    • Grip the top of the clear panel and lift it upwards, and pull the ADC cable through the hole.
  4. Apple Studio Display M7649 Rear Panel Replacement: stap 4, afbeelding 1 van 1
    • Remove the grey back panel by lifting the bottom and pulling the ADC cable through the hole.
Eindstreep
Alan Truong
566 Reputatie
3 handleidingen geschreven
Cal Poly, Team 3-20, Maness Winter 2010 Lid van Cal Poly, Team 3-20, Maness Winter 2010
CPSU-MANESS-W10S3G20
4 Leden
15 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 12
Altijd: 3,710
