Ga door naar hoofdinhoud
Apple Studio Display M2454 CCFL Inverter Replacement
Wat je nodig hebt
  1. Apple Studio Display M2454 CCFL Inverter Replacement, CCFL Inverter: stap 1, afbeelding 1 van 2 Apple Studio Display M2454 CCFL Inverter Replacement, CCFL Inverter: stap 1, afbeelding 2 van 2
    • First remove the three 2mm hex screws from the top of the monitors stand.
    • Then, remove the four 2mm hex screws on the corners of the back panel.
    • Finally, the back panels can be removed by pulling the main cable through the opening and sliding the panels away.
  2. Apple Studio Display M2454 CCFL Inverter Replacement: stap 2, afbeelding 1 van 1
    • Remove the metal backing.
    • Remove the single screw at the top and the two screws at the bottom of the monitor with #2 philips head screwdriver.
    • With the screws removed, push metal backing toward back of monitor to release its clips and pull away.
  3. Apple Studio Display M2454 CCFL Inverter Replacement: stap 3, afbeelding 1 van 2 Apple Studio Display M2454 CCFL Inverter Replacement: stap 3, afbeelding 2 van 2
    • The CCFL inverter board is the smaller of the two circuit boards with two wires and a ribbon cable running out of it.
    • Remove the two cables on the left side of the board, using a pin to insert into the two small holes and then pull out.
    • This step may be easier with two people.
    • Do not insert pin in hole with force or you risk damaging the connector.
  4. Apple Studio Display M2454 CCFL Inverter Replacement: stap 4, afbeelding 1 van 1
    • Remove the ribbon cable on the right side of board by pulling it away from the LCD main board with hand.
  5. Apple Studio Display M2454 CCFL Inverter Replacement: stap 5, afbeelding 1 van 1
    • Remove the top philips head screws holding the board to the monitor with #2 philips head screwdriver.
  6. Apple Studio Display M2454 CCFL Inverter Replacement: stap 6, afbeelding 1 van 1
    • Remove the bottom philips head screw and pull the CCFL Inverter board away from monitor.
    • To replace this part with a new one, simply follow these directions in reverse using the new board.
Eindstreep
Één andere persoon heeft deze handleiding voltooid.
Dylan Perry
177 Reputatie
5 handleidingen geschreven
Cal Poly, Team 13-27, Maness Winter 2010 Lid van Cal Poly, Team 13-27, Maness Winter 2010
CPSU-MANESS-W10S13G27
4 Leden
9 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 10
Altijd: 6,744
