Ga door naar hoofdinhoud
Acer Nitro 5 AN515-57 RAM Replacement
Wat je nodig hebt
  1. Acer Nitro 5 AN515-57 RAM Replacement, RAM: stap 1, afbeelding 1 van 2 Acer Nitro 5 AN515-57 RAM Replacement, RAM: stap 1, afbeelding 2 van 2
    • Shut-down your laptop and unplug the battery connection.
    • Remove any other device attached to the laptop.
  2. Acer Nitro 5 AN515-57 RAM Replacement: stap 2, afbeelding 1 van 1
    • Remove eleven screws from the bottom case of the laptop using a Phillips #00 screwdriver.
  3. Acer Nitro 5 AN515-57 RAM Replacement: stap 3, afbeelding 1 van 2 Acer Nitro 5 AN515-57 RAM Replacement: stap 3, afbeelding 2 van 2
    • Slide an iFixit opening tool into the front lip of the laptop and slowly move your way around the chassis.
    • Make sure not to slide the tool too deep as it can damage the board.
  4. Acer Nitro 5 AN515-57 RAM Replacement: stap 4, afbeelding 1 van 2 Acer Nitro 5 AN515-57 RAM Replacement: stap 4, afbeelding 2 van 2
    • Disconnect the battery by either using the iFixit opening tool or your fingers.
  5. Acer Nitro 5 AN515-57 RAM Replacement: stap 5, afbeelding 1 van 3 Acer Nitro 5 AN515-57 RAM Replacement: stap 5, afbeelding 2 van 3 Acer Nitro 5 AN515-57 RAM Replacement: stap 5, afbeelding 3 van 3
    • Use your fingers to pull the silver latches on either side of the RAM away from each other.
    • The RAM will pop up by a few centimeters.
    • Remove the RAM from the laptop.
  6. Acer Nitro 5 AN515-57 RAM Replacement: stap 6, afbeelding 1 van 1
    • Reconnect the battery pins
    • While reconnecting the battery, try not to touch the metal prongs.
  7. Acer Nitro 5 AN515-57 RAM Replacement: stap 7, afbeelding 1 van 2 Acer Nitro 5 AN515-57 RAM Replacement: stap 7, afbeelding 2 van 2
    • Place the back panel on to your laptop and gently press on it until it snaps in place.
    • Screw the back panel back in.
    • When turning on your laptop the first time after installing new RAM, it may take the laptop a few minutes to turn on.
Eindstreep
Één andere persoon heeft deze handleiding voltooid.
Hanzala Mir
170 Reputatie
1 Handleiding geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 4
Afgelopen 7 dagen: 50
Afgelopen 30 dagen: 148
Altijd: 4,477
