Ga door naar hoofdinhoud
Acer Chromebook CB3-431-C5EX Battery Replacement
Wat je nodig hebt
  1. Acer Chromebook CB3-431-C5EX Battery Replacement, Bottom Panel: stap 1, afbeelding 1 van 1
    • Working on your device while it is turned on may result in electric shock. Make sure to shut down and unplug your device before you begin.
    • Turn device over so the bottom panel is facing you.
  2. Acer Chromebook CB3-431-C5EX Battery Replacement: stap 2, afbeelding 1 van 1
    • Remove the eight 4mm Phillips #0 screws.
    • Remove the two 6mm Phillips #0 screws.
  3. Acer Chromebook CB3-431-C5EX Battery Replacement: stap 3, afbeelding 1 van 2 Acer Chromebook CB3-431-C5EX Battery Replacement: stap 3, afbeelding 2 van 2
    • Insert a plastic opening tool into the crack between the bottom panel and the side of the computer.
    • Gently pry the panel off the computer by continuously pulling up and on the panel and moving the plastic opening tool around the crack until the panel comes off.
    • There are several clips holding the cover in place.
    • Remove the bottom panel and set it aside.
  4. Acer Chromebook CB3-431-C5EX Battery Replacement, Battery: stap 4, afbeelding 1 van 1
    • Remove the two 4mm Phillips #0 screws on either side of the battery pack that are securing it in place.
  5. Acer Chromebook CB3-431-C5EX Battery Replacement: stap 5, afbeelding 1 van 2 Acer Chromebook CB3-431-C5EX Battery Replacement: stap 5, afbeelding 2 van 2
    • Disconnect the taped white 8-pin cable on the bottom right of the battery pack.
    • Use thumbnail to pull on the small protruding tabs on either side of the connector.
  6. Acer Chromebook CB3-431-C5EX Battery Replacement: stap 6, afbeelding 1 van 1
    • Carefully lift the entire battery pack out of the laptop.
Conclusie
7 andere personen hebben deze handleiding voltooid.
Elsa Bassett
414 Reputatie
1 Handleiding geschreven
Cal Poly, Team S17-G3, Banghart Spring 2017 Lid van Cal Poly, Team S17-G3, Banghart Spring 2017
CPSU-BANGHART-S17S17G3
5 Leden
10 handleidingen geschreven
2 opmerkingen
A heat gun is listed as a need tool, but the instructions do not mention using it.
Medium strength (blue) threadlocker compound should be used during reassembly.
Stephen Gertsch - Antwoord
why didnt it stop giving instruction I think I got the wrong battery pak no more acer for me acer 14 they dont know what batterty to send you what a joke LOL
woody wilson - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 13
Afgelopen 30 dagen: 70
Altijd: 8,641
