Ga door naar hoofdinhoud
ASUS Q524U Hard Drive Replacement
Wat je nodig hebt
  1. ASUS Q524U Hard Drive Replacement, Hard Drive: stap 1, afbeelding 1 van 1
    • Turn the laptop on its back, and place it on a flat and smooth surface. Identify the location of the back panels screws.
  2. ASUS Q524U Hard Drive Replacement: stap 2, afbeelding 1 van 3 ASUS Q524U Hard Drive Replacement: stap 2, afbeelding 2 van 3 ASUS Q524U Hard Drive Replacement: stap 2, afbeelding 3 van 3
    • Remove all ten 1.3mm screws on the outer edge of the back panel using the T4 screwdriver.
  3. ASUS Q524U Hard Drive Replacement: stap 3, afbeelding 1 van 1
    • Using the opening tool or spudger, remove the back panel by working your way around the perimeter and pry it open gently.
  4. ASUS Q524U Hard Drive Replacement: stap 4, afbeelding 1 van 1
    • Remove the back panel, exposing the motherboard.
    • Set the panel aside, skin up to avoid scratches.
  5. ASUS Q524U Hard Drive Replacement: stap 5, afbeelding 1 van 1
    • Using the T4 screwdriver, remove the four 1.3 mm screws connecting the hard drive to the motherboard.
    • The hard-drive is located in the bottom left corner of the motherboard.
  6. ASUS Q524U Hard Drive Replacement: stap 6, afbeelding 1 van 2 ASUS Q524U Hard Drive Replacement: stap 6, afbeelding 2 van 2
    • Once all the screws are removed from the port, lift the hard drive out of its casing. After, disconnect the hard drive from the motherboard.
Eindstreep
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 13
Afgelopen 30 dagen: 38
Altijd: 3,268
