Ga door naar hoofdinhoud
8BitDo NES30 Pro Gamepad Button Replacement
Wat je nodig hebt
  1. 8BitDo NES30 Pro Gamepad Button Replacement, Button: stap 1, afbeelding 1 van 2 8BitDo NES30 Pro Gamepad Button Replacement, Button: stap 1, afbeelding 2 van 2
    • Hold the controller with its back facing towards you.
    • Insert an opening pick between the L1 or R1 button and the backplate, and pry the backplate off of the controller.
  2. 8BitDo NES30 Pro Gamepad Button Replacement: stap 2, afbeelding 1 van 2 8BitDo NES30 Pro Gamepad Button Replacement: stap 2, afbeelding 2 van 2
    • Place the controller face down on a solid surface.
    • Remove the seven screws with the Phillips #00 screwdriver.
  3. 8BitDo NES30 Pro Gamepad Button Replacement: stap 3, afbeelding 1 van 1
    • Lift the body of the controller up and away from the controller's face and buttons.
  4. 8BitDo NES30 Pro Gamepad Button Replacement: stap 4, afbeelding 1 van 2 8BitDo NES30 Pro Gamepad Button Replacement: stap 4, afbeelding 2 van 2
    • Lift away the black rubber pads that sit between the face buttons and body of the controller.
  5. 8BitDo NES30 Pro Gamepad Button Replacement: stap 5, afbeelding 1 van 1
    • Lift the buttons out of the face of the controller.
  6. 8BitDo NES30 Pro Gamepad Button Replacement: stap 6, afbeelding 1 van 2 8BitDo NES30 Pro Gamepad Button Replacement: stap 6, afbeelding 2 van 2
    • Align the notches of the face buttons to put them back into place.
    • Each button has a unique notch pattern so it can't be replaced incorrectly.
    • Attach the rubber pads by placing their smaller and larger holes around the matching size pegs.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
2 opmerkingen
Hello there, any idea where I can find those black rubber pads for replacement ? mine is torn.
Thx
Ben Kakita - Antwoord
sorry, i try to search every where, have a tone for other controller, even have for 8bitdo snes, but not for nes 30 pro.
if you find it, answer on that chat. Good luck
Freeman loran - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 36
Altijd: 1,859
