Ga door naar hoofdinhoud
2014 Subaru Impreza Hatchback Brake light Replacement
Wat je nodig hebt
  1. 2014 Subaru Impreza Hatchback Brake light Replacement, Brake Light: stap 1, afbeelding 1 van 1
    • Turn off car engine
  2. 2014 Subaru Impreza Hatchback Brake light Replacement: stap 2, afbeelding 1 van 1
    • Open the trunk of the car.
  3. 2014 Subaru Impreza Hatchback Brake light Replacement: stap 3, afbeelding 1 van 1
    • Unscrew the both the 2 cm Phillips #3 screws encircled in the image shown with a Phillips #3 screw driver.
    • Unscrewing them will allow you to take out the brake light.
  4. 2014 Subaru Impreza Hatchback Brake light Replacement: stap 4, afbeelding 1 van 2 2014 Subaru Impreza Hatchback Brake light Replacement: stap 4, afbeelding 2 van 2
    • Unscrew both the 2 cm Phillips #3 screws by turning the screwdriver counterclockwise.
  5. 2014 Subaru Impreza Hatchback Brake light Replacement: stap 5, afbeelding 1 van 1
    • Gently pull the rear light straight back.
  6. 2014 Subaru Impreza Hatchback Brake light Replacement: stap 6, afbeelding 1 van 1
    • Upon opening the brake light, you should see three bulbs in total.
    • The brake light is the one on the bottom.
  7. 2014 Subaru Impreza Hatchback Brake light Replacement: stap 7, afbeelding 1 van 2 2014 Subaru Impreza Hatchback Brake light Replacement: stap 7, afbeelding 2 van 2
    • To remove the brake light, twist the light bulb socket counterclockwise.
    • The bulb should come out as shown in the second image.
  8. 2014 Subaru Impreza Hatchback Brake light Replacement: stap 8, afbeelding 1 van 1
    • To remove the bulb, gently pull out the bulb from its connector.
  9. 2014 Subaru Impreza Hatchback Brake light Replacement: stap 9, afbeelding 1 van 1
    • Gently insert the new bulb into the connector.
    • Carefully insert the bulb, as the bulb is made of glass it is susceptible to breaking and cutting you if a lot of force is used to insert it in the connector.
  10. 2014 Subaru Impreza Hatchback Brake light Replacement: stap 10, afbeelding 1 van 2 2014 Subaru Impreza Hatchback Brake light Replacement: stap 10, afbeelding 2 van 2
    • Reinsert the bulb back into its initial position.
    • Gently twist the bulb clockwise to further tighten the bulb.
  11. 2014 Subaru Impreza Hatchback Brake light Replacement: stap 11, afbeelding 1 van 1
    • Gently push the rear light cover back into its initial place.
  12. 2014 Subaru Impreza Hatchback Brake light Replacement: stap 12, afbeelding 1 van 2 2014 Subaru Impreza Hatchback Brake light Replacement: stap 12, afbeelding 2 van 2
    • Reattach both the 2 cm Phillips #3 screws back into their place by screwing them clockwise with your Phillips #3 screwdriver.
Eindstreep
Één andere persoon heeft deze handleiding voltooid.
Manas Tripathi
232 Reputatie
1 Handleiding geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 11
Afgelopen 30 dagen: 92
Altijd: 1,103
